I just got Roxio Creator 2010 for windows 7. When I run the copy and convert, it shows 100% done, but locks up and won't close down. There are no software updates, any ideas? I have to use the task manager just to shut it down. It seems to run quickly until the very end. It shows 1 task of 1 done, but locks up.
SOURCE: roxio creator has problem and will shutdown
If you haven't already, you might want to uninstall then reinstall the program. Sometimes a program will seem to install correctly when it hasn't or, become corrupt over time. If you do this and continue to experience the same issues with the program then you may need to move onto troubleshoot the issue further.
SOURCE: windows 7 creator 2010 install
Hello and thank you for using Fixya's services.
Roxio Creator 2010 is compatible with Windows 7 and was actually created for it. Are you experiencing problems?
Please let me know and I will be glad to help!
SOURCE: i installed roxio creator 2010 successfully but I
go to my computer/program files/roxio easy creator 9 suite and copy and paste the quick launch icon and place it on your desktop
SOURCE: Is Roxio 9 compatibility with windows 7?
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site:
The following products have been designed to be Window 7 compatible (as of January 2010):
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
To reverse this at the end of installation, go back into MSCONFIG and select Enable All and restart (that can be done once installation is complete).
