First off, this is a VERY messy job. It likely requires full disassembly to chassis of the printer. The waste ink pad likely spans the entire foot print of the printer and is many pads thick, at least it does on other similar models. When we clean these, at a Cartridge World store, we rinse the pads, which are special dense felt material and then centrifuge the water and ink out, which can take multiple cycles. Low end ink printers generally do have have service manual readily available to aid in disassembly so you are on your own.
It is doable but be aware of what came from where and in which order.
Here are the instruction for how to reset the counter. Warning: Resetting the counter without cleaning the pads WILL result in waste ink overflowing out of your printer and onto whatever the printer is on, eventually.
http://www.printerclinic.info/2008/08/reset-waste-ink-absorber-error-waste.html
SOURCE: Canon pixma 150 waste ink absorber full
Hi there
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
But some time when you get the chance do clean the waste tank out.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: locate waste ink absorber pad
no cleaning only remove that pad and buy replacement from printer accessories supplier.
SOURCE: My Canon PIXMA iP2000 photo printer Waste Ink Absorber
Hi there try see if this will work
Reset ip2000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
