i tried doing those things but didn't work. now the blinking is now faster and continuous than before.i tried doing those things but didn't work. now the blinking is now faster and continuous than before.
AnonymousJun 16, 2008
yep same problem. im going to try that flashlight thing. mine will turn on however but you have to give it a good 10 min....yep same problem. im going to try that flashlight thing. mine will turn on however but you have to give it a good 10 min....
AnonymousJul 01, 2008
blue light blinks and the monitors black
do i need to service
tried turning it on and off but soon as you plug it in the light starts blinking.
and no responce for on or off just blinking lightblue light blinks and the monitors black
AnonymousDec 10, 2008
Blue light flashes, but screen stays blank. No repsonse to reboot, or presseing any keys. Self test with signal cable does not work.Blue light flashes, but screen stays blank. No repsonse to reboot, or presseing any keys. Self test with signal cable does not work.
AnonymousMar 20, 2009
MY SAMSUNG 931B WON'T COME ON THE LIGHT IS JUST BLINKING BY THE POWER SWICTH WHAT CAN I DO TO FIX THE PROBLEM.MY SAMSUNG 931B WON'T COME ON THE LIGHT IS JUST BLINKING BY THE POWER SWICTH WHAT CAN I DO TO FIX THE PROBLEM.
You can't post conmments that contain an email address.
You have to
check if you can see the image on the screen or not after it went blank (Power on both CPU and monitor) by shining a flashlight into the
screen, not directly but find the best angle to the screen and take a look very
closely. If you can see the icons or any image, there will be a minor problem.
Like mine, I can see window image using flashlight and check lamps inside. Some
of them were broken and it is very easy to replace. If you cannot see anything on
the screen, there'll be some problems with inverter board. If you have
soldering tool and want to fix it by yourself, check the caps first. It may
cause this problem. Some caps might show leaking or burn spot on the board
because of too high temp. If you don't have soldering tool, you better go get a
technician to do so. Thank you
THER IS NO SIGNAL FROM THE PC DUE TO WHICH UR MONITOR IS NOT DISPLAYING THE SCREEN KINDLY CHECK THE CORD OF THE MONITOR WHICH IS CONNECTED TO THE PC OR MAY BE UR PC IS NOT BOOTING UP DUE TO WHICH U PC IS NOT GETTING DISPLAY
This model was released in 2001, you need to open it up and look for bad caps with bulging top first, the problem can also be in the backlight inverter circuits. Post back what you see so we can guide you further, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
First palce to check will be the power supply section, look for bad caps (bulging tops), post back what you find inside so we can guide you further, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
