All batteries will eventually fail to hold a charge. The battery chemistry and how you charge it can change how long the battery will last. The DMC-FS4 has a Lithium-ion battery so it shouldn't have as much of the memory issue of older rechargeable batteries. (This is the "you routinely recharge the battery when it's at 50% then it always stops working at 50% charge" problem.)
How old is your battery? Eventually you will need a new battery but the time to replacement will depend on the number of recharge cycles. With a Li-ion battery, I'd expect several thousand recharges before failure. Temperature and usage will effect this. The battery does lose charge even when not used.
Be careful, some versions of the firmware look for Panasonic's specific batteries or a "that match the Panasonic rigorous specs".
I've seen a few devices where the charger failed before the battery. If a new battery doesn't seem to be charging, replace the charger. I hope this helps.
Battery powered vehicles like scooters and golf carts have trouble going up hill because smaller electric engines aren't powerful enough or made for nothing more than flat land. You could have a bad battery or the battery isn't being charged enough. I know someone that has a golfcart and it takes approximately 48 hours to charge full. You may want to check the manual about charging times.
The batteries are dead. The battery in these scooter need to be kept
charged or if not in use for a long time charged every 3months.
Otherwise, like what to you, they will go dead. The chemicals in the
battery have deteriorated to the point where it won't hold a charge.
Replacement batteies are available at:
We had the same problem that I found to have a very simple fix. It seems all that needed to be done was hold in the reset button a few seconds while the battery charger was plugged in and the light on the charger turned to red and the battery charged again. Seems like too easy of a fix but it worked for my kids scooter.
