Dear sir,
I have a gp 405 machine, and there is error E677, Plz. give me perfect solution on this problem.
Thank you sir,
Sandip R. Jagdale. 9850742174, nasik
E805 (The fan rotation is faulty.)
If no detail code is indicated,
suspect the feeder fan (FM1) or the
reversing guide cooling fan (FM9).
Is the connection of these fans
normal? Is the drive signal of the fan
identified in the previous step about
22 VDC while the fan is rotating orabout 12 VDC otherwise?
That is one side with the fans,
Secondly, if the fans are found right, then for sure you need to change the DC Controller.
Regards!
Originally Posted by logimix
Could somebody tells me... what this error (E805 - Canon GP 405) is... and how to resolve it? thanks a lot. john pl check detail code after 805 .Fan related fault. Also power supply(composite)
