How can i get the info off my hard drive? can i put the drive in something else? we have some old towers from previous machines. we have it backed up on an external drive with norton ghost. not currently installed on anything else. we have 1 thinkpad laptop, 1 imac desktop and two older ibm desktops in the attic.
Get external hard drive shell, place the hard drive in it, the connect via firewire or usb all your info should be intact except if its a crash
Only two option to retrieved all the info of your hard drive.
1. you can purchase hdd enclosure around 10usd, fixed your hdd inside enclosure, then connect the usb from enclosure to computer then copy data from enclosure to computer hard drive.
2. turn off your computer and unplug it. remove the casing of system unit. in your hdd, remove the jumper cap and transfer to slave position and then install the hdd by connect the hdd power cable and ribbon cable. return tha casing and power up your computer. open my computer and you can see additional drives then open each until you can find the data you want to retrieved.
You can connect your hard drive to the older ibm desktops and then you can take the backup of the hard drive and also use them with your old ibm computer.
