Press AC press and hold [RATE SET] for two seconds, "SET" will appear on left of screen. Press TAX+, type in the new tax rate, press and hold [RATE SET] for two seconds, then press AC.
Exchange rate changes every day. You need the current exchange rate. Get it from google. Google will even do the math for you. Just type in the google.com search box
"56 euro to pounds"
And it will tell you that today the answer is 50
Good luck
rind the exchange rate, perhaps at a site such as: http://www.x-rates.com/ so, for example, 1 euro is apparently worth 1.4765 US$ at the moment. if you have 13.82 US$ divide by 1.4765 to get 9.36 euro. if you had 32.00 euro then multiply by 1.4765 to come up with 47.25 US$
When you press the [M/EX] key, it toggles between conversion mode and memory mode. You will see "EXCH" on the display when in conversion mode. C1, C2, and C3 are three conversion rates. C1 is your home country currency, and so it is always set to 1. C2 and C3 are rates for two other countries, which you can change. For example, if you want to set a conversion rate of $1 to 0.95 euros, here is what you would do (using C1 for US dollars and C2 for euros): 1. Press [AC] 2. Hold [SET/%] for about two seconds until "SET" appears 3. Press [C2] to select currency 2 4. Input the conversion rate (0.95) and then press [SET/%] to store it in memory You can check the currently set rate at any time by pressing [AC] and then [C2].
How do I perform a currency conversion?
If you want to convert 100 euros to US dollars, you would do the following (assuming you are using C1 for US dollars and C2 for euros): 1. Press [AC] 2. Enter 100 and then press [C2] 3. Press [C1] to convert to dollars 4. To convert back to euros again, press [C2] You can also perform a currency conversion within a calculation. How much in US dollars would five items selling at 100 euros cost? 1. Press [AC] 2. Enter 5 [×] 100 and then press [C2] 3. Press [C1] [=]
For the MS-80TE and MS-100TV this suggestion works - with the MODE select the EXCH than hold down the SET button. on the screan SET EXCH will appear, press the C2 /the C1 is by default 1/ and set the rate, press SET again and you are done
Hope i helped !
Press AS
Hold Down RATE SET (%) for about 2 second and the correnty rate appears on the display
Imput the conversion rate and the press rate set (%) to store it in memory.
Best regards
Alberto
step 1 pess the AC button
step 2 press and hold for two seconds the % button
step 3 press the tax+ button
step 4 input 6
step 5 press the % button
that should be the tax set
you can check it is set correctly by pressing the AC button and then the tax+ and 6 should be displayed
