To change the device control panel display language
1. Press MENU/ENTER.
2. Use the < or the > button to select Common settings, and then press MENU/ENTER.
3. Use the < or the > button to select Language, and then press MENU/ENTER.
4. Use the < or the > button to select the language that you want.
5. Press MENU/ENTER to save your selection.
The device automatically restarts.
If this does not work you can always reset the printer to factory settings,but keep in mind you have to set it up again.
To restore the factory-set defaults
2. Use the < or the > button to select Service, and then press MENU/ENTER.
3. Use the < or the > button to select Restore defaults, press MENU/ENTER, and then press
MENU/ENTER again to confirm your selection.
Hope this helps good luck thanks.
