Yamaha HTR-6130 Receiver Logo
Posted on Mar 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to connect sony video camera to yamaha htr 6230? I put the yellow in the video white in left and red in right audio in the v-aux in the front of the receiver. For some reason it is not displaying the picture on the tv. How do i get the picture to show on the tv?
Anonymous
Level 3:
President:
  • Master 2,992 Answers
  • Posted on Mar 23, 2010
Anonymous
Master
Level 3:
President:
Answers
2992
Questions
Helped
1093495
Points
9665
How are you connecting the TV to the receiver? The receiver offers HDMI, component video and composite video outputs. The one you use will depend on what inputs are available on your TV. Whichever you choose, have the appropriate cables connected at both ends. Then make sure the proper source is selected on the TV and your camera output should be visible. The receiver manual is available for download at Yamaha's site if you need a copy for connection details.
Radio diagram for 2016 nissan versa
Hi there, Try this...
Radio 12V yellow + radio, white 20 pin plug, pin 19 Radio Ground (chassis, base audio); black/white (except base audio) - radio, white 20 pin plug, pin 20 Radio Ignition blue + radio, white 20 pin plug, pin 7 Radio Illumination lt. green (parking light); black (dimmer, without navigation) +,- radio, white 20 pin plug, pins 9, 8 Power Antenna black + radio, gray 3 pin plug, pin 1 Left Front Speaker (+/-) gray - pink +,- radio, white 20 pin plug, pins 2 - 3 Right Front Speaker (+/-) beige - violet +,- radio, white 20 pin plug, pins 11 - 12 Left Rear Speaker (+/-) white - red +,- radio, white 20 pin plug, pins 4 - 5 Right Rear Speaker (+/-) blue - yellow +,- radio, white 20 pin plug, pins 13 - 14 Aux. Audio Input Left (+/-) yellow - green +,- radio, white 32 pin plug, pins 31 - 15 or white 24 pin plug, pins 10 - 11 Aux. Audio Input Right (+/-) blue - green +,- radio, white 32 pin plug, pins 16 - 15 or white 24 pin plug, pins 12 - 11 RSE Video (+/-) green - (shield) (rear view camera video) +,- radio, white 24 pin plug, pins 16 - 15 Satellite Radio 12 Volts (built into radio on premium audio)
Good Luck
Mr.Mike
Panasonic TV, TC-P50S2.Yamaha DVD Player DV-C6280.Yamaha Receiver HTR-5450.DVD audio working fine thru receiver. Not sure where to place white/yellow cords to get video feed.
Hello. Usually when you mention white and yellow, there should be a red also, the red and white are right and left audio and the yellow is the video. The audio should be connected to the receiver, and if the receiver has video inputs and outputs, that should be connected to the same receiver input as well, but if the receiver doesn't have video capability, the yellow should be connected to the TV video input. I hope that helps.
Connect roku to switch box to surround system
there must be red and white rca outputs, those are audio lines(stereo) get rca cables connect from the tv and into the AUX in the stereo amp, select aux on the amp front panel and you will get the quality sound you want,
Having trouble connecting a ipod to the back of the reciever with rca cables. I plugged in to the V-AUX and also put the input to AUX on the reciever. still no sound
I think the V-AUX is a video input, not audio. Look for a red and a white RCA female input to connect the cable. Those represent the right and left, respectively, audio.
2answers
When I connect my Wii to my Yamaha HTR-6130 through the front V-Aux jacks, i hear sound but no image. It says " Listening to Dock" on the front display. Can you help?
On this receiver the tv must be connected to the Monitor RCA Composite (yellow) output in the rear when you use another Composite input. You can't connect the Wii with the Composite and expect to use the tv with the HDMI - this unit doesn't have an onboard converter.
Once you have connected it correctly just select as a source the front connectors.
I am hooking the system to a yamaha stereo receiver and i need to know what jacks to hook it to out or in 3 wire or just 2 because of no video just audio red white yellow the stereo reciever just has ...
Let me write some basic things about audio and video signals and cables. Stereo audio has two channels, left and right, usually red and white (or black) jacks. You plug in audio cables. Video signals in old receivers are marked in yellow. If your receiver does not have video (yellow) input, usually located above the two audio inputs, you will not be able to watch any video signal through the receiver. The receiver will only play the sound of dvd, since its left and right audio channels are properly connected. Just aux and phono inputs are not enough. Hope this may help.
1helpful
Yamaha HTR-5830 does not work with Sony PS3 optical cable connection. There is no sound at all. Do I need an HDMI cable. Right now I only have component cables which work fine with the red and white...
Make sure you have the "audio input mode" on "Auto" it's a small button on the front of the Yamaha. Then go into the PS3's Audio setup and make sure it's set to Digital. Hope this helps
Xbox 360 to the yamaha htr 6130
All you is connect the to audio jacks (red,white or black) to the receiver input or aux port then switch the receiver to aux or line in
2answers
I have a Yamaha HTR-6130 Reciever of which I want to connect my Nintendo Wii and XBox 360 to. I already have my PS3 connected to the HDMI and the audio connected to the red & white a/v inputs, but I've...
Not sure if this is your problem, or not, but the red and white wires are for audio. There is a separate yellow wire for composite video. Alternatively, you can use the red/green/blue (RGB) connector cable for component video.
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
