When the monitor is turned on it appears to work - the "acer" name comes up and then the words "no signal". As soon as no signal comes on the sceen it goes to black and the light turns orange. The pc has a new video card installed and tests okay on other monitors, a new cable between pc and monitor has been installed also - still no success
If it does the same with other PC then you need to open it up and first thing to look for are bad caps in the power supply, see example of failed monitors due to bad caps, transistors, transformers, lamps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside, and always replace with good quality caps such as PANASONIC FM or FC series from DIGIKEY.
