Broderbund The Print Shop 21 Deluxe Full Version for PC Logo
Posted on Mar 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Install new CD for printing projects.
I have new PrintMaster software. I am running Windows XP, version 3. Nothing happens when I insert installation disc.
Anonymous
Level 2:
Champion:
  • Expert 241 Answers
  • Posted on Mar 23, 2010
Anonymous
Expert
Level 2:
Champion:
Answers
241
Questions
0
Helped
49846
Points
369
Goto Start/programs/Accessories then to Windows explorer or my computer then goto ur CD drive then click on setup.exe
1helpful
2answers
I have PrintMaster Premier 8.0, I would like to install on my computer running windows 7. It will not download. I do not want to purchase another version. Is there any updates that I can download to allow...
1. These instructions from Microsoft will explain how to run a compatibility troubleshooter for your software.
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
2. Contact Broderbund directly at 800-395-0277. I use their Print Master software also and they are very helpful at the customer service area.
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
2helpful
I have used PrintMaster 10 for a number of years on my old computer-XP. I recently purchased a new computer and wish to put the program on my laptop( Windows 7). I tried choosing the compatibilty method...
The only solution with this older software that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate (or are willing to upgrade to one of these versions), you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them. You can't have a printer installed on both the main computer and the virtual one at the same time. You will be asked to uninstall the printer if you try.
Your other option is to upgrade to PrintMaster Platinum 18.1, see http://www.broderbund.com/ for details, which is compatible with Windows 7. This will import your Printmaster 10 projects.
I hope this helps.
My wife has been using Printmaster for years and has created thousands of projects. Her latest version is 18. We got a new computer with Windows 7 and it said that version 18 is not compatible. So we...
Installing PrintMaster 18 on any computer requires .NET Framework 1.1 to be installed on the hard drive. If NET Framework 1.1 is not installed, it will be installed from thePrintMaster 18 install disk before PrintMaster 18 is installed. If possible download .NET framework 1.1 If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant" in Windows 7 will display this message.To continue with the installation, select "Run Program".
2helpful
Trying to install Printmaster 15 for Windows 7. Is that possible?
Apparently no, it does support only Windows 98 / NT 4 / Me / XP. However, here is a thing you can try if a program cannot be run under Windows 7 because of compatibility issues, which is the case with Print Master Platinum 15. You right click on the executable file that will install the application and click Properties. Select Compatibility tab and check Windows XP SP3. If it installs do the same for the EXE file that will run the application. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Hi i am trying to install the printmaster platinum 2.0 version i have windows xp but i keep getting a java error
I installed PrintMaster Platinum 2011 and it first said that I didn't have the correct version of Java for my Mac. I downloaded the required version and was able to proceed with the installation. Did the error happen to say what version of Java is required? If so, going to the Java website and getting the newest update for Windows XP would probably allow you to go ahead and install PrintMaster.
1helpful
2answers
I could not install PrintMaster Publishing Suite 7.0 on our new computer running Windows 7. Is this software compatible with Windows 7? Is the a version to upgrade to that is compatible that we can work...
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
I have purchased PrintMaster Gold version 18 three times and returned two of them. My computer is operating on Windows XP service pack 2. My computer does not seem to find any data on the install disk....
You might have a problem with your CD/DVD drive. Try inserting the CD in another computer. If the files are shown, replace your CD/DVD drive or just add another CD drive to an empty bay of your computer.
5helpful
4answers
My printmaster Platinum 10 version will not install on Vista.
downgrade too XP 10 is not compatible with Vista
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
