Cars & Trucks Logo
Anonymous Posted on Mar 23, 2010
Rear brake noise after brake replacement
Just replaced rear rotors and pads on 1995 camry with 4-wheel disc, no abs. I used ceramic pads, but i am getting noise from left rear when driving at low speeds(scuffing sound) and noise from both sides when braking. I lighlty sanded rotors and cleaned with brake clean before installation, and torqued wheels to specs and with proper bolt down pattern.Neither wheel is getting hot after driving car for nominal time(15-20 mins) just that aggravating noise. Also, rotors are scoring on the caliper pad side (inside) already(100 miles on since repair) but the wheel side of rotors are still smooth. Is this common?
  • Anonymous Mar 25, 2010
    Thanks for the reply. I pulled wheels and calipers today and found one of the pad hold down clips had shifted and was rubbing the rotor. As for all the other suggestions, I previously did all but rebuild caliper pistons. Thats the first time I have had a clip shift on me, but it happens I guess.
  • Anonymous May 11, 2010
    Did you replace the brake hardware (slider clips and springs)? What condition were the pieces in? Do the pads have good freedom of movement in their slider clips? Make sure that the clips are flush with the calipers and not protruding to contact the rotors. Did you re-install the pad shims? What condition were the pistons in? What is the condition of your brake fluid? Did you bleed the brakes? If the pistons look old and tired (on a 95 the originals certainly would be), and you do not want to spend the money on new ones, it may be worthwhile to remove the pistons, drain them completely, flush and refill with clean fluid, then re-install and bleed the lines.
Anonymous
Level 2:
Scholar:
  • Expert 90 Answers
  • Posted on Mar 23, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
90
Questions
0
Helped
52809
Points
254
Probably a dumb question, but if there is a backing plate, did you make sure it isnt bent and hitting the rotor? you never want to sand new rotors, although i dont think it would cause this concern. i would suggest lightly scuffing up the brake pads. this will eliminate any noise caused by the contact of the rotors and pads. if it goes away then you know its a problem with the pads/rotors.
scoring of only the inside rotors would make me think that possibly the caliper slides are frozen up. make sure they move quite freely on the slides. it is not uncommon for brake pads to score rotors though.
but brake noises at low speeds that dont' change when applying light brake pressure are usually some sort of metal or something contacting the rotor.
3answers
2015 Malibu was making hissing type noise . Changed brake pad rear passenger side where noise was. Now making a grunting or groaning sound when applying brakes at low speeds.
Did you replace ALL the pads on BOTH sides? They are usually sold as sets of 4 so use all 4. Did the pistons in the callipers push back smoothly? Sometimes a 'sticky' piston can cause a pad to rub causing noise.
Is the sound constant or does it pulse under light braking? Pulsing can possibly be a warped rotor 'tapping' the pads as the the warp passes them. The warp can be tiny and you'll need a specialist tool, (A Dial Gauge Indicator), to measure for it.
Deeper tone noises can suggest it is the rotor causing the issue.
Commonly rotors can last between 30,000 to 70,000 miles depending on how hard they are used. Did you check the condition of the rotors when you changed the pads. On a 2015 model there is a chance these are the factory installed discs. So it could be worth you changing them anyway.
1helpful
I have a 99" Ford Windstar LX, When I press on the brakes the pedal shakes and it makes a grinding noise after driving a few miles the abs light goes on. I have replaced, pads, rotors, master cylinder,...
if you replaced all the brake parts I would check your hub bearings and cv axels if the noise is coming from front if the noise is in the rear check your e brake shoes located inside of the rear brake rotors if u have disc rear brakes or your rear brake bearings .. hope this helps
On my 1995 toyota Camry the disc brakes are screeching when I hit them.
hi any kind of screeching noise normally means uve got a metal on metal contact so i wd say u probally need ur pads changing also the rust that forms is totally normal when not used for a while goodluck
2answers
How to change brake pad and check rotors
Brake Pads Removal & Installation Front for_car_toy_cam_02-04_sst_frt_dsc_asm.gif
To Remove:
  1. Drain brake fluid to ½ full level in reservoir.
  3. Remove the front brake caliper assembly.
  4. Remove the 2 anti-squeal shims from each of the 2 brake pads.
  5. Remove the wear indicator from each of the 2 brake pads.
To Install:
NOTE: When replacing worn pads, the anti-squeal shims must be replaced together with the pads.
  1. Using a large C clamp or equivalent press piston into the caliper.
  2. Apply disc brake grease to the inside of each anti-squeal shim.
  3. Install the anti-squeal shims on each pad.
  4. Install the pad wear indicator clip to the pads.
  5. Install the pads with the pad wear indicator plate facing upward.
  6. Install the brake caliper with the 2 mounting bolts. Torque the bolts 25 ft-lb (34 Nm).
  7. Install the front wheels.
  8. Fill the master cylinder with new clean brake fluid.
  9. Pump the brake pedal several times to seat the brake pads.
To Remove:
  1. Drain the brake fluid to ½ full level in reservoir.
  2. Remove the rear wheels.
  3. Remove the caliper slide pins.
  4. Remove the caliper slide pin bushings (TMMK made) (Kentucky).
  5. Remove the rear brake calipers.
  6. Remove the 2 brake pads with the anti-squeal shims.
  7. Remove the anti-squeal shims and pad wear indicators from brake pads.
To Install:
  1. Using a large C clamp or equivalent press the piston into the caliper.
  2. Coat both sides of the outer anti-squeal shim with pad grease.
  3. Install anti-squeal shims to each pad.
  4. Install wear indicators on the 2 brake pads.
  5. Install the caliper slide pin bushings (TMMK made) (Kentucky).
  6. Install the rear brake caliper with the slide pins. Torque the slide pins as follows:
    • TMC made (Japan): Torque the caliper slide pin 25 ft-lb (34.3 Nm)
    • TMMK made (Kentucky): Torque the caliper slide pin 34 ft-lb (47 Nm)
  7. Fill the master cylinder with new clean brake fluid.
  8. Pump the brake pedal several times to seat the brake pads.
  9. Install the rear wheels.
prev.gif next.gif Brake Rotor Removal & Installation Front To Remove:
  1. Remove the front wheels.
  2. Remove the front brake caliper assembly.
  3. Remove the front brake pads.
  4. Remove the 2 bolts and caliper mounting bracket.
  5. Place match marks on the disc and axle hub.
  6. Remove the front wheel disc.
To Install:
  1. Align the match marks and install the front disc.
  2. Install the brake caliper mounting bracket. Torque the bolts 79 ft-lb (107 Nm).
  3. Install the brake caliper. Torque the bolts 25 ft-lb (34 Nm).
  4. Install new gaskets and connect the brake hose to the caliper with the banjo fitting bolt. Torque the fitting bolt 22 ft-lb (29.4 Nm).
  5. Fill the reservoir with brake fluid.
  6. Bleed the brake system.
  7. Install the front wheel.
Rear To Remove:
  1. Remove the rear wheels.
  2. Remove the brake caliper assembly.
  3. Remove the brake pads.
  4. Remove the 2 bolts and the caliper mounting bracket.
  6. Remove the rear disc.
To Install:
  1. Align the match marks and install the rear disc.
  2. Install the rear brake caliper mounting bracket. Torque the bracket bolts as follows:
    • TMC made (Japan): Torque the bracket bolt 46 ft-lb (61.8 Nm)
    • TMMK made (Kentucky): Torque the bracket bolt 34 ft-lb (47 Nm)
  3. Install the rear brake caliper with the slide pins. Torque the slide pins as follows:
    • TMMK made (Kentucky): Torque the caliper slide pin 32 ft-lb (43 Nm)
  7. Install the rear wheel
Recently replaced the original equipment front brake pads on a 1997 Toyota Camry V-6 with ceramic brake pads. Also replaced the front brake rotors. Used disc brake quiet/lube at time of installation. I am...
You did not mention working on the rear brakes, so I must assume that the rear brakes are still original equipment. Perhaps the grinding noise is coming from the rear.
3answers
2007 camry brakes vibrating
Installing new brake pads on toyota camry solara 2006 front rotors and pads and rear pads. Steering wheel would shake while breaking on 50+ miles per hour speeds. All fixed now.
2helpful
Replace rear brake pads
Rear disc brake pads offer better performance and are not as affected by moisture like conventional brake shoe style brakes are. Rear disc brakes are similar to front disc brakes. The main difference is that rear disc brake systems must incorporate the emergency brake system. There are two methods widely used for the emergency brake with rear disc systems. The first system is a brake shoe inside the brake disc that is actuated by the emergency brake lever. The second is a screw style actuator inside the brake caliper. When activated the brake pads are forced into the brake disc and held tightly by the emergency brake lever.
READ COMPLETELY BEFORE STARTING
Step 1 - Identify Rear Disc Brake Components
rear_brake_pads.jpg Rear disc brake assembly includes; rear brake disc, rear brake pads, brake caliper mount and a caliper mounting screw. (Note: Some vehicles do not have the rotor mounting screw.)
Step 2 - Removing the Rear Brake Caliper Mount Bolts
rear_brake_pads_2.jpg To replace rear brake pads and rotors the rear brake caliper needs to be removed. First loosen the rear brake caliper mount bolts and remove them. Turn counter clockwise.
Step 3 - Lift Rear Brake Caliper from The Caliper Mount
rear_brake_pads_3.jpg After the caliper mount bolts have been removed, gently lift the brake caliper from the caliper mount. Inspect the caliper slides; they should move freely in the caliper mount. Remove rear brake pads and hardware.
Step 4 - Removing Caliper Mount Bolts
rear_brake_pads_4.jpg With a socket wrench or other appropriate removal tool, loosen the rear brake caliper mounting bolts. Remove bolts and lift the caliper mount and remove it from the vehicle. Remove the retaining screw from the disc mounting hole. Tap the rotor gently to release any rust that has accumulated between the rotor and bearing hub. Lift brake rotor from wheel hub holding on tightly, using both hands. You do not want to drop the rotor.
Step 5 - Removing Rear Brake Rotor
rear_brake_rotor.jpg Remove the retaining screw from the disc mounting hole, tap the rotor gently to release any rust that has accumulated between the rotor and bearing hub. Lift brake rotor from wheel hub, hold on using both hands and do not drop.
Step 6 - Install New Brake Rotor
rear_brake_rotor_2.jpg Check the new rotor against the old brake rotor to make sure they are the same size. Clean the mating surface on the wheel hub before the new brake rotor is installed. Reinstall rotor retainer screw.
Step 7 - Reset Rear Brake Caliper
rear_brakes_7.jpg Before new brake pads can be installed, the rear brake caliper must be reset. The reset tool winds the piston back into position so the new brake pads will fit. This style of brake caliper will not compress with a clamp tool; it can only be reset with the proper reset tool.
Step 8 - Reinstall Rear Caliper Mount and Install New Rear Brake Pads
rear_brake_rotor_3.jpg After the caliper has been reset, reinstall caliper mounting bolts and make sure the bolts are tight. Then match up the old brake pads to the new brake pads. They should be exactly the same except, of course; the old ones will be worn out. Check the new brake pads for proper fit and install any brake hardware that is required.
Step 9 - Remount Rear Brake Caliper
rear_brake_rotor_4.jpg Reinstall the brake caliper, align brake pad hardware and reinstall caliper mounting bolts. (Note: align the rear peg of the brake pad to the groove in the caliper piston.) Recheck and retighten all caliper and caliper mount bolts. Bleed brake system to relieve any air in the system. Before driving the vehicle, push the brake pedal down and let it up slowly. This operation forces the brake pads to travel to the brake rotors. DO NOT DRIVE VEHICLE until proper brake pedal operation resumes. When test driving vehicle listen for any unusual noises during the operation of the brakes.
WARNING! Always have the vehicle under inspection on level ground, in park with the emergency brake on. Always wear protective eyewear, gloves and necessary clothing before inspection or work begins. Never crank an engine over when anyone is near the battery or engine. Always have an operational fire extinguisher close by, obey all first aid instructions in the event of an injury. Never stand in front or behind a vehicle when cranked over or running. When engine is cranked over keep hands and clothing away from rotating components. Never move a car without proper brake pedal operation.
3answers
Brake pad replacement. My brakes are making a squeeking sound as I drive. Sounds like rotor or brake pad problem.
Here is Video of How to replace front brake pads and rotors, and rear brake pads on toyota camry solara 2006
Toyota Camry 2005-Brake pads noise problem
The rear brakes should last from 30000 to 60000 miles or 50000 to 100000 kms. So something is wearing out your brakes too fast. Are you doing the work or some shop. I also assume you have discs and not drums since you mention pads and calipers. I am not certain but usually you need a tool to turn the pistion in when putting in new pads. I would make sure the pads are releasing properly by raising rear of car, stepping on brakes a few times (with engine off and try see if wheels are free by spinning by hand, also try to use handbrake a few times and release it and see if wheels spin freely. Maybe rears always applied. Notice burning smell, are discs glazed from heat? Are you using really cheap pads. Also check the proportioning valve which will decrease pressure to rear brakes during hard braking. Do you notice rear wheels squeling during hard braking. Do you have antilock brake system? Also are you using good quality pads and rotors.
2helpful
Replaced rear brakes, Alarms still active
i have a 2003 toyota 4-runner my brake and abs vsc are on and it has a beeping loud noise.....what do u think is the problem?
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
