It sounds like the inverter was defective, the monitor will be fine for few seconds then go off but power light still stay on with Green. You can contact with manufacturer for repair service if it still under warranty.
Oddly enough, I had the same exact situation with mine when I hooked it to a PC with Windows Vista. Since then I have it on a machine with Windows 7 and it is just fine. Not sure if it is/was a setting difference, or driver difference between the 2 windows. I did try several setting adjustments with the Vista machine, with no difference. The 7 machine was simply a plug and play.
bu if it just got black screen with vista and working with 7 then the monitor is working fine. all monitors in now day are plug and play. is it possible you need to select the input when you go with vista? or try with different monitor to verify the vista video output is good.
