Although
gas range oven may prove useful for cooking and baking, they may fail
to ignite if they aren't properly maintained and set up. Lighting a gas
range often involves simply turning a knob; however, blockages from food
particles and debris caught in the burners, improper burner cap
installation and gas supply are common problems that interfere with your
gas range oven's performance. A few troubleshooting guidelines may
solve these problems safely.
Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
Clean the burners if you have gas but your burners still
won't ignite. To clean the burners, lift the burner caps
Inspect the small vertical holes on the side of your burners
for dirt, food and debris. The gas won't ignite if they are clogged.
Scrape dirt, debris and food from the vertical holes using a pointy
object such as a toothpick or paperclip.
Reinstall the burner caps properly. If they are tilted or
wobbly, the gas may not ignite. Install the caps on the right burners.
Some burners are smaller than others, so match the caps to the
appropriate burners.
5
Move the burner knob to the "Lite" position and wait for the
gas to ignite. If it ignites, rotate the knob to your desired setting.
If it doesn't ignite, contact a qualified appliance technician.
from I review I found it might be this...Simple replacement of Glow Bar igniter requires removal of entire front panel with many screws
so sounds like your igniter might be shot - it heats up to ignite the burners - easy fix - get a long torch lighter and just light the gas after turning it on -
Sounds like the pressure regulator on the stove is going bad. The pressure regulator is located in the back. Your gas supply line should connect directly to it.
If on LP, you may need to change the jets on the burners on top. Most times, when oven and broiler work and top doesn't, and you have spark, your jets are wrong size. Look on back of unit for a cardboard attached to unit, should have jets stuck to cardboard, if notgo to store where you bought unit and buy jets.
Gas range repair aid -such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
If you look at the oven igniter in the bottom portion of the range, (where the gas controls are) look to see if the igniter is glowing hot. If not, replace your igniter. This is the part that starts the burner and keep it lit. When you get a new igniter DO NOT TOUCH THE ELEMENT PORTION of the igniter. Or it will pre-maturly fail. Good luck.Hope this helped ya!
