that can not be the boards number look in the pci slot or cpu area for number of board then go to intel support web site type in board numbers then download drivers then install one by one ok
Sure you can do that...as long as you have enough sata power adapters instead of molex. If u dont, there are adapters that take molex to sata and you can get them cheap at a repair shop
your operating system is might corrupt or maybe the configuration of *********** board is not compatible with your old settings try to reformat your hard drive and make sure to follow the instruction in installing your operating system thats the best solution a can give to your problem i hope this can help
all motherboards have a size known as "form factor"
*********** baord is Micro ATX,
youll have to buy a case that can fit that motherboard in or buy another motherboard that will fit in your case, youll have to find out your dell model number to find the form factor, easiest way would be search your old motherboard number
No, don't automatically assume the mobo is broken. Look closely at all the pins. There should be a 4x2 rectangle of pins, maybe coloured. They'll say things like 'PWR-SWTCH' and 'çPU-LIGHT' Connect those up, and your mobo manual should have specific details on what goes where.
