Lexmark X5150 All-In-One InkJet Printer Logo
Posted on Mar 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lexmark X5150 Scanning in pdf but saves in jpeg
Using scanner and scanning to .pdf format when I go to open the file it is saved in .jpeg how can I rectify this? Does X5150 support pdf format?
Kemlin joseph
Level 1:
New Friend:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Contributor 3 Answers
  • Posted on Feb 07, 2014
Kemlin joseph
Contributor
Level 1:
New Friend:
Teacher:
Answers
Questions
0
Helped
603
Points
13
I would like to recommend use Kernel For Image to PDF converter software. It is an affordable tools that can easily convert image to PDF without hassle. Read more detail http://pdfutility.blogspot.in/2013/12/image-to-pdf-conversion.html
Anonymous
Level 2:
  • Expert 148 Answers
  • Posted on Mar 23, 2008
Anonymous
Expert
Level 2:
Answers
148
Questions
Helped
45498
Points
285
Need to install adobe reader software
How do I name and save a scanned document in HP C4480 (Windows)?
Hello, Robert -
I hope I am correct in assuming you have the user's manual for the HP Photosmart C4480. Just in case you do not, this is the link to the web page where you can download and save the manual (PDF format - Adobe Acrobat Reader software needed, free):
https://support.hp.com/us-en/product/hp-photosmart-c4400-all-in-one-printer-series/3655558/model/3655559/manuals
After downloading the PDF document save it (Save As) to your Documents folder and give it a name you can find again easily - maybe: HP Photosmart C4480 Manual.
How to save a PDF file:
- With your computer, open the PDF document in Adobe Acrobat Reader
- Move cursor to upper left corner of page and left click or tap on FILE
- In drop down File menu, move cursor to SAVE AS and left click or tap on it
- In Save As window which opens, move cursor down to CHOOSE A DIFFERENT FOLDER and left click on tap on that "button"
- In window which opens choose DOCUMENTS in the Documents Library
- In File name box near the bottom of the Documents Library pop-up window, enter the name with which you want to save the PDF document, Example: HP Photosmart C4480 Manual
- Left click or tap on the SAVE button
Note: The steps above will be similar to what you will need to do after scanning any document.
The instructions for scanning start in Chapter 10, Page 64 (Image 304 of the PDF format manual).
Open the scanner through your computer. It is easier to save the document later by operating the scan functions through your computer.
With the scan application open on your computer run the scan process. After scanning the document, you will need to save it. First, you will need to determine the format in which you want to save the scanned document: PDF, JPEG (photo image), GIF, etc.
After choosing the format for the scanned document, in the proper file name box, enter the name for the document you wish to save.
Examples:
Correspondence 2018-Feb-18 Brother
Photo Brothers-Family 2018-Feb-18
Deed of Sale 2018-Feb-18 House
Get the idea? I like to give a date to my scanned document names to help identify them better.
Once you have entered the file name, click or tap on the SAVE button.
Note: I always like to open the saved document from the Documents folder to verify it was saved. Plus, my scanner attaches a number at the end of every file name. After closing out the saved document and closing the scanner winder, I go back and Edit the file name, removing the added number (digits) from the saved file name.
The video you will find with this link:
http://esvideo.es/video/watch/ult2ORqN1eGRiLQ=
is for those who use Windows 8 or 10. Even if you use another Windows operating system (I use Windows 7), you can probably figure out what to do. The video goes through the scanning and saving process step-by-step.
Best wishes.
1helpful
What is meant by PDF as used in scanning?
PDF is the format in which your scanned document will be saved at. In some cases you have options to save either as PDF, Jpeg depending on your scanner and the scanning software. Hope this helps!
Cannot save in pdf format after scanning thru hp g3010 scanner using win7 pro
Hi abdul_haq779,
This problem couldd be resolved by printing the format that you get via your scanner for e.g. jpeg into pdf , by using a free pdf printer tool.
Once you have an image scanned via your scanner , you can just print the image in pdf mode.
1helpful
3answers
New all in one printer/scanner. when I scan I get:- Adobe reader could not open 'scan_Doc0001.pdf'
Might need a bit more information about this: But I'm presuming you scan your document and save it as a pdf document using the built in HP software?
Couple of things to try:
1 - have you got the latest version of Adobe Reader? It may be that you are using an older version - the pdf document specification has been updated over the years and it may be that you're saving the pdf using a newer version of the pdf format than adobe reader is able to read.
2 - Adobe reader isn't the only pdf viewer, there are numerous other pdf document viewers (some free some not) You could try another pdf viewer, like Foxit Reader (free to use) and see if that can open it?
3 - When you save the scan, make sure that in the Save Dialog box it is really saving it as pdf. Common mistake is that people often just save a file with .pdf and expect the program to know that you want to save as pdf. When you scan there are several other file formats that you can use (Tiff, Jpeg etc) Is is possible you're saving the file as Tiff or Jpeg but with a .pdf file extension? If you're not sure, re-scan the document and resave it, but don't use a file extension, let the scanning program do that, see what it saves it as?
4 - check where you're saving the pdf on your computer? Is the place you're trying to open it from, the same as the place you've saved it?
1helpful
How to use scanner for mp 210 series
You can Scan image from the machine into a computer and save them in,JPEG,TIFF,PDF or BITMAP format.
Scanning Methods:Scanning Using The MP Navigator- Using the MP NAVIGATOR you can Scan process and save documents to your computer.On the MP Navigator 3.0 double click then open it and via:
1 Easy Photo Print(Photo Printing)
2Arcsoft Photo Studio(Photo Image editing )
I shall try to help you
Thanks
Fujitsu s510 scanning photos to jpeg
Please open the "paint" from"start/all pograms/accessories/paint".
one when you open the paint, click on file and select the option scanner and camera wizard.
when it open click on scan and when scan get complete click on file and "save as " and select the formate "jpeg" and save it.
1helpful
I HAVE A LEXMARK X9350 AND WHEN I SCAN ITEMS, THE FILE SIZE IS HUGE. EG 1 PAGE = 3MB. HOW CAN I REDUCE THE SIZE OF THE FILE
See the manual for X9350 on page 119.
The software application must be used for saving files to a specific format that you can select from the menu on the computer.
Standard scans are often saved as bitmap with the extension .bmp .
Select another file format like jpeg with the extension .jpg or .jpeg, when you want to view the scans in photoview afterwards.
Another option is to save the file in a format that can be read with Adobe Reader, selecting .pdf format.
A last option is to reduce your file size, changing the scan settings:
( I wouldn't advise; this can result in unclear copies ):
Advanced scan settings can be changed on the computer as well:
See reducing e.g. "scan resolution" and "color depth" on page 120.
Use the link support for Lexmark 9300 series for more help.
2helpful
How to scan a document using Canon MX310 to Microsoft Word
you can try it by using the scanner option on the control panel. If you are using windows operating system, go on start menu, select control panel and double click scanners & cameras. Double click the scanner online and start scanning the documents. Save it in the format you want but it is usually default as jpeg.
scanned documents usually saved as .pdf file if you run the scan option directly on the printer. By pressing the SCAN button the printer. So do not use this option if you do not want the documents to be saved as pdf files.
1helpful
Pdf and jpeg format scanning problem in Canon iR2018 copier
Yes,you do have to buy the sent kit.But remember the sent kit Scan to e-mail and not directly to the computer.Your company have to have a mail server to be able to work properly.Adobe have software that you can buy that chance word document to PDF.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
