To copy names and numbers to the
SIM card
1 Select Menu > Contacts.
2 Scroll to New contact and select
Options > Advanced > Copy to SIM.
3 Select an option.
When you copy all contacts from your
phone to the SIM card, all existing SIM
card information is replaced.
To automatically save names and
phone numbers on the SIM card
Options > Advanced > Auto save on
SIM.
3 Select an option.
To save contacts on a memory card
Options > Advanced > Back up to m.
card.
SIM contacts
SIM contacts can contain names and
numbers only. They are saved on the
SIM card.
Hi. In order for you to copy numbers to sim card follow these steps :
1. Go to Address book
2. Press Options
3. Then go to Advanced
4. Find the option copy to sim card
5. Choose the contact that you want to copy or choose to copy all contacts.
If you want to save a new contact number and want it to be saved to your sim card follow these step :
2. Press Options
3. Go to Advanced
4. Choose Auto Save on Sim Card
Hope this information helped solve your problem. Thank you and have a nice day!
The only information you can save on sim card is your contact number and messages. Music, video and picture can not be save on sim card but on memory card.
To copy contact number from phone to sim card, go to phone book, press the option button and scroll down to copy number from phone to sim card. You can also do same thing on messages too.
yes and no you can save the contacts to the sim card but you cannot save the calender events to the card cause its only for contacts just go to the contacts and look for something like save contact to sim hope this was helpful:)
you can save all your contacts to you sim if your sim memory is not full. Follow these steps:
unlock keypad, select "contacts" option from menu then select "copy" option in "contacts". Selecting "copy" will left you with two options : 1. From sim card to phone.
2. From phone to sim card.
Then select "From phone to sim card". It will ask "One by one" or all.
You can select any option and contacts will be copied to your sim card. If its ask for "delete original" or "keep original" , its your choice to keep copy of contacts in sim card or not.
You'll probably find they're already on the sim, if not here's how to copy them over.
Open contacts, options, SIM contacts, SIM directory; you should see all contacts that are on your sim. If there's none there, select back which will take you to your contacts; choose options again, scroll to mark/unmark press select then mark all, all contacts should now have a tick beside then. Then options again, copy & lastly to sim directory.
well usually before you add a contact it asks you where to save it to the sim card or the phone unfortunately if u save it to your phone you cant just pull out the sim and put it in the new phone you need to save contacts and anythingels u want transferred to your existing sim card
How Do I Copy Contacts From My SGH-d807 Phone To The SIM Card?
To copy an address book contact to the SIM card follow the steps below:
While in standby mode, press the left soft key for Menu Select Address Book (8) Select Contact List (1) Select the desired contact entry, stored in your phone's memory, using the navigation keys Press the left soft key for Options Select View (1) Select one of the contact phone numbers, using the navigation keys Press the left soft key for Options Select Copy (3) Select SIM (2) Press the left soft key to Save the single contact phone number to the SIM card
Note: Each phone number for a contact must be individually saved to the SIM card
PS-Not sure about updating/replacing entries though, which is what you may have been asking about
