I have checked all the hoses and cleaned out all the drain areas within the dishwasher--it still won't drain at the end of cycle--l;eaving a good deal of water in the bottom of the dishwasher. How can i fix this problem?
A clog in the drain line or air gap (if there is one) is the usual
reason that a dishwasher won't drain. Often the problem is at the point
where the drain line attaches to the garbage disposer or household
drain line. If you remove this line, you can clear any debris from the
hose or hose connection. Be sure to reattach the hose before starting
the dishwasher again.
Many dishwashers use a drain valve with an
electric solenoid. When electricity flows to the solenoid, the valve
opens and diverts the water to the drain. Sometimes the solenoid, or
the diverting lever, sticks and prevents the dishwasher from draining
or filling properly. Try to free up the solenoid to lubricate the
lever. Otherwise, you may have to replace the solenoid or pump
assembly. With these systems, the motor always rotates in one
direction. When it's energized, the drain valve diverts the water.
Other
dishwashers simply reverse the direction of the motor to drain the
dishwasher. These units don't have a drain valve. Instead, there's a
drain hose connected directly to the pump housing.
