Toshiba 22LV505 22 in. LCD TV Logo
Posted on Mar 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I turn on the tv, Get a blank screen with
Please help me , my toshiba tv model 22LV505 is unable to show any channels. Icant even ge to the channel option to set it to auto search.previously I was able to get to lock and enter my password and try to get to channel option but stil can't change it. How do I get this tv to go back to factory default settings so I can reset the channels? Please let me know , I'm on standby waiting for a response .Thanks!!!
Chi Chu
Level 3:
  • Toshiba Master 8,457 Answers
  • Posted on Mar 22, 2010
Chi Chu
Toshiba Master
Level 3:
Answers
8457
Questions
0
Helped
2822669
Points
26282
Unplug it,replug it back an hour later,the tv should set back to the factory setting.
I connected my GE TV model 13GP301 to a Magnavox DTV Digital to Analog Converter using RF cable. I mistakenly changed the setting on the TV to the video cable connection (red, white, yellow). Now no...
if this shows "vid" on screen turn it back to tuner input with input button on original remote.... could be marked who/input on some....go to mrremote.com if you haven't got it..............good success, meder's tv service
1helpful
Toshiba 22LV505 TV-DVD:
Check the DC filter caps in the power supply first. Check the 24vdc (or 18vdc for this 22" model) to see if it goes away when the screen goes black.
There are main AC fuse, backlight inverter fuses, T-CON fuses.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Toshiba 22lv505 TV/DVD Region Code Error
maybe the spindle motor is turning defect causing not to spin the disc naturally,its time to have to check that to the Toshiba service center
What do I need that I can get local TV off air?
You need a suitable VHF/UHF antenna. Then you simply "Tune" VHF/UHF frequencies on the TV and it should find channels and automatically "Lock" onto and store them.
Unable to view DVD on TV
Here is a solution buy a coax to RGB converter they run from $20- $30 at radioshack this will shore up that problem as it will use channel 3 as the input of choice.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
1helpful
LOST PICTURE & SOUND - UNABLE TO RE-PROGRAMME
i have a technika lcd26 207, the power button works and the light comes on, but i have no picture or no sound, just a complete blank, black screen. any suggestions please?
DVD PLAYS FINE BUT GET A BLANK SCREEN WHEN USING THE TV WITH SAT
Your signal may be low. Try chaning the channels and adjusting your antenna. I hope this solution is helpful. Please take a moment to rate this solution.
Need remote code for 22lv505 for dish network
Your code is 750....... Program the remote control in TV mode and then in VCR **repeating the steps** (or AUX - press 1 before entering the DVD code) mode.
How to program your dish network remote for your tv:
1. Use the device’s buttons or its remote control to turn on thedevice.
2. Press and hold the mode button for the device you want the remote to control, for about three seconds. When all the other mode buttons light up, let go of the mode button - that mode button should now be flashing. For example, hold the TV mode button for a TV until all of the other mode buttons light. When you let go, the TV mode light will flash.
3. Only for the AUX mode, Use a number button to enter 1 for a second VCR or DVD player
4. Use the number buttons to enter one of the device codes that I have given you.
5. Only for Limited Mode, Press 1.
Limited Mode- allow you to only use the remote to Power, Mute, and adjust Volume on your tv.
You cannot change the tv channel when the remote is in limited mode. You can only power on your
VCR in limited mode
****Note: Skip this step if you do not want to use Limited Mode.****
________________________________________________________________
6. Press the POUND (#) button. If you entered the code correctly, the mode button flashes three times.
7. Press the blank POWER button to test if the code works for the device. If it does, the device should turn off.
8. Turn the device back on and try some other buttons to make sure they work. Sometimes, the blank POWER button works when other buttons don’t. If the code works for other buttons
** Stop Here**
Let me know if this helps..
1388f48.jpg If I have helped you, dont forget to rate!!!
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
