Hi There
I have found the code you are looking for and i hope this helps you. Let me know how it went.
F/09
Overflow
Condition
If
the Overflow contact on the pressure switch is
Closed for
more than 60 seconds and Overflow condition will
occur.
In an Overflow condition, the Door will remain
locked, and
the Drain Pump will run constantly, even if
PAUSE/CANCEL
is pressed twice and the Display is cleared.
Unplug the
unit to service.
thank you for writing to fix ya.
Best Regards Richard
Fl code indicates an overfill condition. If the washer is empty, then you likely have a problem with the water level pressure switch. If the washer is full of water and will not drain, you likely have a problem with the drain pump or the washer drain line.
If the washer is full of water, make sure that the washer drain is clear and working properly. Check the drain hose for kinks or clogs. If you find no problems with these issues, I recommend that you manually drain the washer using a wet/dry shop vacuum. Check the drain pump and connecting hoses for problems. You may need to replace the drain pump of water will drain out of the washer properly but the pump will not work properly. A clog in the check ball assembly at the bottom of the tub can also prevent the washer from draining properly.
