Lenovo IdeaPad S10 - 42312BU Notebook Logo
Posted on Mar 21, 2010
Connecting ideapad and tv with vga - tv recognizes ideapad - but ideapad not recognize tv
Anonymous
Level 1:
  • Contributor 942 Answers
  • Posted on May 09, 2010
Anonymous
Contributor
Level 1:
Answers
942
Questions
0
Helped
209501
Points
57
Pls call our tech support line at 1-877-4-536686 so that our associate would have a remote session with your pc to solve your problem...
1helpful
Connect toshiba nb500 netbook to RCA tv win 7 stater with VGA cable and s video no displaying in the monitor tv didn't recognize
Does you notebook shows any connection information after connect to tv. If not you need to install. If this didn't work you have to change VGA cable. If not your notebook doesnot supports the tv
My television won't recognize my laptop
TV must be set to view source to PC. most of the laptop have VGA output this like output projector. Pls read the proper doc on connecting your laptop to TV..
Lg tv wont recognize pc
You may want to lower the resolution on your laptop and try again !!!
When I connect my unibody macbook pro to my old tv using a vga to tv converter, my computer doesn't even recognize the disyplay.
When you connect your tv to your mac, make sure the cables are plugged into the TV first, and then plug your mac into the computer.
But a vga to tv converted doesn't make much sense. Your connection should be mini-display from your mac, to an adapter to either VGA, DVI, or HDMI depending on your TV connection type.
PC TO TV
The TV will recognize any operating system. You can use a VGA cable to connect to the television if the TV has a vga port. Then select the PC input for the TV. If the connection is white and larger if may be a DVI connector. You will need a DVI cable in that case or a DVI to vga adapter.
TV will not recognize my computer
turn down the resolution of the computer to less than 1024 x 768 and select the pc input on the television
2answers
My LCT 2662 (AKAI) will not recognize my laptop via a VGA
Update the video drivers on your laptops. Reboot both devices.
PC to TV Hookup
It is very likely that TV supports only some resolution while in vga mode. I would try 1280x 1024 and keep changing it lower until TV recognizes signal from PC
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
