I've replaced the steam valve assembly because the machine was leaking. The 'ventilate' message was showing before we did this...we can't get rid of it!....no water will come through the steam wand (it's clean), we've tried opening and closing it repeatedly but we only get a slight trickle every so often. It just tells us to close the knob then the 'ventilate' message appears again. We've checked the flow meter it seams fine. It does get hot on the top of the machine on the right hand side....any sugestions???
The top right hand side can get hot if you have the cup warmer switched on.
I am finding that the steam boilers are starting to block up and the steam lines are getting scaled up.
If you have access to compressed air,undo the boiler and lines and blow them out.
I have had coffee jammed in the inlet of the flow meter,blowing through it will be a good test.
Good luck
Testimonial: "coffee came throu' as before.....then switched to steam..it normally says ventilate here..steam! Hurray!!!"
The cup warmer is switched off.
Sorry!!!
Didn't realize I'd commented
three times!....Didn't think it had worked!
