Hi Mike. I am Kelly. I noted you went the chat route first before your p;ost ended up here.
Take the drain hose from the drain and maually drain the machine until you can not get any more water out of it. Then unplug the machine for 5 - 10 minutes so that the filter sensor will reset. For some unknown reason it seems the sensor is working but it did not trip and error code on the display panel.
If it still does not work after the manual drain you may have to open the filter door and open the filter to allow it to completely drain and do the same 5 - 10 min plug out of wall / power off routine.
Kelly
Just one more comment... if you do get it to work again you can do a bang up job cleaning cycle by running a cycle wth 1/4th cup dishwashing Powder and about 1 cup of bleach. It will descale everything and avoid the fussy performance your seeing now. I would do the cleaning cycle about every 90 days.
Kelly
