After the maximum number of password entry attempts is exceeded by
supplying incorrect passwords, and the BlackBerry smartphone is restarted, the
following error appears:
It says Reload Software: 513
The BlackBerry® Device Software must be reloaded on to the BlackBerry
smartphone
It sounds as if you are mis-typing your password -- and after the maximum number of allowed attempts, it automatically wipes the device clean (as a security precaution, on the assumption that you are not the "owner" of the device). What it also does, during the password retries, is to show you the password in clear text after some number of failed attempts.
Reload 513 appears when you have entered wrong password from some specified number of time.Due to this the phone wipes of the data fully.Now you need to reinstall the software.
Go to below website and this will show how to update the software
i'd attempted 10 times USB pwd, and now my phone s/w was all whipped off. msg on screen is reload software 513, plz help. i'd just got my Curve 8520 3 days ago...
all you need to do is sync your blackberry with your blackberry desktop manager and run the application loader. you will lose all data on the phone because you will be re-installing the software
After typing an incorrect password ten times and restarting the BlackBerry smartphone, the following error appears:JVM 513
All of the data and applications on the BlackBerry smartphone have been deleted and The BlackBerry® Device Software must be reloaded on to the BlackBerry smartphone (Due to the Java Virtual Machine (JVM) error, the BlackBerry smartphone will not show a Connected state in the BlackBerry® Desktop Manager. Proceed to reload the BlackBerry Device Software using the Application Loader)
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 and 4.6, perform the following steps:
1) Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
2) Double-click Application Loader.
3) Click Add/Remove Applications.
4) Type your BlackBerry smartphone password and click OK.
5) Select the check boxes next to the names of the applications you want to load.
6) Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
7) Click OK. 8) Click Next > Finish
9) When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager.
the Application error 513, reset message says that the device OS is toasted and needs to be rebuilt. In order to do this, you need to have Blackberry Desktop manager on your computer, your data cable, and a download for your device software. Either from blackberry or your carrier.
The easiest method is to download and install the device software. Once it's installed, launch desktop manager and plug in the phone. If the phone is detected, you will be prompted to update. Follow the prompts.
If not, you will have to do it the hard way. open command prompt (start>run>cmd) and goto C:\program files\common files\Research in Motion\Apploader
Then choose Loader /NOJVM
That's going to rebuild the blackberry.
the password i kept typin in was wrong on my blackberry curve, so it started wiping everything and now it says JUM error 513 and it wont get into my phone,the only way it turns off is by taking the battery off,i tried reseting it and it goes to the same screen? what can i do to get in my phone?
