You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/http://67.20.82.163/
IS IT POSSIBLE YOU ARE USING THE KEY FOR A DIFFERENT VERSION OF WINDOWS. MAKE SURE YOU ARE USING THE SAME CD WHICH CAME WITH LAPTOP. REGARDS.
PLZ. DON'T FORGET TO RATE
Generally this occurs when F12 is pressed multiple times causing the keyboard to stop responding because the keyboard buffer is full.
At boot, when the Dell Splash Screen Appears press the F12 key once when the progress bar is 70% across the screen (System should beep ONCE) then select the optical drive and press spacebar when prompted. The keyboard should work fine after that.
