Mold growth is a common problem due to tight seals and poor drainage.
Pull back the rubber or plastic around the tub or basin to reveal the problem. You should also check your detergent dispenser as this is another common area for mold growth. Remove any visible mold. You can use a solution of water and dish detergent or bleach (1 part bleach to 10 parts water). You could also use bleach wipes to do this depending on how stubborn the mold is.
Because of the set-up of the washer, mold can also tend to grow in pipes, traps, and outside the drum where you can't see it.
You can run an empty load on the hottest water setting with 1 cup or more of bleach. Run an empty load on the hottest water setting with 1 cup or more of vinegar. Use a product designed to attack build-up from detergents and fabric softeners. Call a repair man to service the parts of the machine you can't see or attempt to do it yourself
However Mold needs moisture to grow. Leave your washer door and detergent dispenser cover open in between loads to allow for complete drying. This will dramatically decrease or eliminate the problem.
2. clean the machine monthly to stay away from the problem.
3. Switch to powder and/or low-sudsing detergent.
Let us know if you need further clarification else please accept the solution.
Thanks for contacting fixya.com
Seems to be a design problem. Water collects in gasket seal and does not drain off. I am looking for a permanent fix. Is this a product defect? Should I call in an LG repairman?
