I have a jazzy power chair i think. i can't find any info on the chair.the chair has been sitting for about 3 yrs. when i push the on button 3 red light 2yellow lights just flash, and chair will not move
Likely 2, 3, 4 or 5 bar flash code. If motors are made by a company like "ELE...." then motor wiring is likely bad inside wire insulation where wires go into motor cap. Rebuild motors and try again. This is a common problem with these motors.
There is a sequence of a button push while moving the joy stick in a certain direction untill it beeps. Check the owners manual for the exact sequence. You can download the manual from Pride's website.
Your version has a Dynamic Controls model controller and joystick. Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand) Turn the chair off, wait 5 seconds, turn the chair back. If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors. 3=Left motor fault 4=Right motor fault 5=Left brake fault (may not be engaged) 6=Right brake fault (may not be engaged) Any other fault code usually means the electronics or wiring is bad and not worth fixing.
the 7 lights indicate a joystick problem which means the joystick/controller will have to be replaced since there is no self repair fix Unless you can locate a good used joystick/controller for cheap (around $600.00 rebuilt) I would return the chair and get my money back Hope this helps
The jazzy probably has a VSI controller and if it is sleep mode then the lights will scroll rather than blink. Now turn on the chair and see if the blinks have a pause between them, ie 4 blinks pause 4 blinks pause etc If they do count the number of blinks and this will give you the error code ie 4 blinks right motor 3 blinks left motor your owners manual should have a chart listing the error codes If not you can contact Pride tech support @ 1-800-800-8586 ask for jazzy tech support
When a chair sits for a long period of time ( four weeks or more) without being charged, the batteries die. To help you with the freewheel mode I would have to know what model of Jazzy it is.
Pride doesn't make a Jazzy 115. Please check your chair and owners manual to get the correct model so we can help. How old is the chair? The flash codes you are getting depend on the model, year it was born, and the tkype of controller installed.
Also, the flash code should be literally, flashes. 2 lights flash twice, stop, then go again, etc. They all mean something, so repost with more info please.
