Lanier 7213 i have a lanier 7213 with the " service call " light on. The start button stay red and i can't use it. I try to reset the trouble turning off the copiers for 10-15 seconds the back on. Nothing happend. thanks
  • 1,326 Answers
Is the copier displaying any numbers or letters besides a service call light. The copier will display more then you are telling. Need a little more info. to give a educated answer or do you want a SWAG answer?
Posted on Mar 12, 2008
SOURCE:
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Lanier copier 5613 Error Code 549 What is it and how do I reset?
SP 5-810, press 1 hold down OK and original type key at same time to reset. -Carl
Nov 21, 2014 | Lanier 5612 Fuser Spring For Picker Finger...
We have a photocopying machine in our office LANIER 7216. Since 3 years we have been using another brand which has more capabilities, but now it's not working and service personel took it for mending....
i dont have knowledge of lanier machines.but the ultimate answer to ur question is that remove the button cell from the main board of the machine for 30 min and then power on the machine without it.refit the cell and wola the password is broken as in other machines
Jun 02, 2011 | Office Equipment & Supplies
Describe your lanier sc 542 Problem Machine turns on and then gives this code.
This is a hot section problem, can be reset by entering service mode (pushing in sequence clear modes 1-0-7 hold stop button down for 5 seconds) but this is a bad code...service call? -Carl
Nov 13, 2010 | Lanier 1205 Copier
I have a Lanier 5245. I am getting an error when
Your duplex is the big box on the right side of the machine push the back side shut against the machine and try again
May 08, 2009 | Lanier 5235 Printer
Lanier 5645 cannot reset printer red button just keeps coming on
when you press the 'red' button, it probably says 'paper mismatch, or load "XXX" paper, and you can override it by selecting one of your paper trays manually? It is likely a "legal size document' and you don't have legal size paper loaded, or something along those lines. Try printing the document after manually selecting the paper size/tray (turning off auto paper select) in your printer preferences dialog box on your PC first.
Mar 02, 2009 | Lanier Office Equipment & Supplies
Dell inspiron 530s is giving me major trouble. When ever I turn it on, the power button lights up and the fan turns on but then thats it. There is no activity on the monitor, just the loud noise of the...
my inspiron 530 giving me trouble. Blue light is on, but the computer goes no where. Try to start by shutting down and restarting but the start sound keeps coming fora long time and nothing happens. So to say having trouble starting and sometimes it shuts down but the blue light stays on. Sometimes I cann't even turn off the computer by pressing blue light - trouble trouble trouble
Feb 22, 2009 | Dell Inspiron 530s Desktop Computer...
Getting light to turn off after changing water filter
Press and hold the lock and light buttons (lock and water on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks
Jul 30, 2008 | Jenn-Air JSD2789GES Side by Side...
Lanier LD032c Photocopier The red spanner light is on and the screen is stuck on 'downloading, please wait'. If you could suggest a way to fix this as we have turned the machiene of to reset and it still...
Try a software reset which involes holding down the * and # (next to the 0) buttons for about 10 seconds until you hear a beap. You should then see "Now loading. Plese wait" and it should start up normally.
Its possible the machine has just locked up. If the above procudure dosen't work power off at the power piont and leave off overnight.
Please advise if any SC codes are present with the spanner for further help.
Feb 05, 2008 | Lanier 1205 Copier
Open Questions:
503 people viewed this question
k24674
Marvin
Marvin
