well , as with all discs, old player will NOT play all CDs.
not even close.
first ask an old guy for CDDA disk or buy one from walfart.
then try that, only these disks work in all players.
other disks may or will not work.
like DVD-R, CD-R and any other recordable disks will fail.
that is the acid test, if the CDDA disk works (real audio disk)
works then the drive is ok, if not, its bad. simple as apple pie.
YES.... to prevent cutting of any factory wiring (this use to be the old install method and requires much more time and expense) and potential electrical fires, you can now buy quite cheaply, what is called a Radio adapter harness.
As you wish to install a Kenwood radio to your Toyota Scion, simply buy an adapter loom which has a 2005 Toyota Plug on one end, with a Kenwood plug on the other (this essentially replaces the wiring loom that came with your Kenwood unit).
So, it's that easy .... Plug and Play.
And... if you sell your Toyota and wish to put your old Toyota radio back in, the original radio just plugs back in. PRESTO !
it sounds like it was installed incorrectly. there must be amps in the car. when the dvd player was installed they hook up a blue wire on the back of the radio. its a power antenna wire . switch it for the blue white wire and youll be in buisness
I had a similar problem with mine
I have just had a technical fault with mine and the only solution i could find was through halfords. If its under warranty they send it off to their supplier AEL to solve. If its no longer under warranty like mine, they send it off at an initial £60 cost which could escalate if the problem is larger.
We have a GMC Envoy which also does not allow us to play the sound from the dvd player through the car's speakers. Although we purchased the vehicle new with the dvd player already installed, it was installed by the dealer, making it after-market. I assume those that were installed in the factory work differently. Maybe this is the case with your's as well. Good luck!!
I had the same problem, HALFORDS sent the unit away to have the firmware re-flashed and now it works perfectly again..... These units were re-called apparently due to problems with the software.
HALFORDS staff may be able to advise you about where the unit can be repaired.
