How can i turn on the av channel
Hi, look for a symbol either on the front of the TV or remote that shows a Circle with an arrow pointing into it from the left
Testimonial: "thank you so so much, so simple but I dont have an instruction manual. Many, many thanks. Angie"
There should be a button on your TV or Remote Control labeled "Input", "A/V", "Video" or "Source". Press that button until you reach the screen that says "AV" or "AV 1".
Make sure that your AV source is the same source that you wish to view from your device. Eg: if the device is connected to AV 1, make sure you select AV 1 on the TV.
To change back to your normal source, simply press the button until you get back to the original source.
Testimonial: "many thanks, a great help"
If none of the above works which it should, wait till the tv is on then power up your device dvd/playstation/ ect and the av should change on its own when the tv gets a signal :-)
