Need to adjust the band on my KC3735BN watch. One end of the pin looks like a screw head. Tried tapping it out on the down arrow. No luck. Any ideas short of taking it to the jeweler?
The arrows show you the direction to push out the pins.
Look for an arrow on the inside of your watch band. The direction the arrow is pointing is the direction the pin should slide out of the band. If your pin is screwed in, you may not see an arrow on the inside of your band.
Look on the edge of the watch band for a small round object, the pin. If the pin head is flat, then it needs to be pushed out. If the pin head has a screw driver groove, then it needs to be screwed out. Depending on the type of watch pin you have, take a sharp pointed tool or a tiny screw driver from a hobby kit or watch tool kit and place it on the head of the pin. You should be looking at the end of the pin on the opposite side from where the arrow is pointing.
Push on the sharp tool to push the pin out of the watch band. You will need to use force to push the pin out. If your pin is screwed in, gently unscrew the pin until it becomes loose. Remove the pin with your fingertips. Make sure to put the pin in a safe place, because you will need it again when resizing the watch band.
On the inside of the band, locate the links with the arrow etched on them. The arrows mark the removable links.Lay the watch on its side on a flat surface with the arrows pointing downward. Be sure to leave about 1/2 cm of space between the bottom of each removable link and the flat surface. Using a 1/32" flat head jeweller's screw driver (or metric size 1.0), insert the tip of the screw driver into one side of the removable links' pin holes. You will find that the pins have an end that looks like a screw head. This is misleading - press down very firmly on the other end. Press downward firmly to make the pin pop out the other side. Be careful not to lose it.Remove the pin on the other side of the arrow-marked link.Repeat as necessary to remove half the needed links. You will remove the other half from the other side of the band to maintain equal band length.Flip the watch over so the arrows are pointing upward.Align the holes in the remaining links. Insert the rounded edge of one of the pins into the open link hole. The pin will go in without trouble until the top.Holding the pin in place, carefully flip the watch over again and firmly push the pin fully into placing using the flat surface. The pin will snap into place.Repeat for the other half of the band as necessary.
This watch has cotter pins. The end that comes out looks like a screw head but it is not. It is a split pin and the end with the split is the large end and needs to come out first. The arrows tell you which way to take the pins out. Use a small punch and push from the side that has no split. This should also be the same direction the arrows are pointing.
Just take a tiny little jewelery screw driver small enough to fit in the pin hole and tap it with anything that you can find. Then pull out other end. Look for arrows indicating which way to remove pin and go in that direction Some pins are like a hairpin and have a split at one end. Replace solid end first opposite of arrow direction. If there are arrows in both directions on the same link; like Fossil for instance, that means that it doesn't matter which direction the pins are removed or replaced. They are solid and they can go back either end first. It's easy. To get the pin in all the way I just used the little screw driver and tapped it in. Good luck.
You really should take it to a jeweler who will have the proper tools to do this without damage to the band or watch, but if you feel you are able and don't mind the chance that you might scratch it.
...you will need a very small (the kind you use for your eye glasses) screw driver -flat head type, and a way to tap (a tack hammer) get a cloth to lay down (dark so you can see the small parts) and work on this surface. Look at the small holes on either side of the band and look for a ( - ) this is the end of the pin that must come out first and this is the direction you will force out the pin from the chamber. To force out the pin you must put the head of the very tiny screw driver on the OPPOSITE end and gently tap the screw driver to push the pin out, once you see a small portion of the pin, pull on it with a pair of pliers, but try not so squeeze it for fear of damage. Repeat at the next pin you wish to remove or 2 or 3 depending on how many you want out. Once you have removed all you need to, hold the links from where you have it separated together and push the pin back up inside the chamber **but make sure it is going back in as it came out---the pin will look sort of like a bobby-pin and the Rounded end goes in first** After you push it in by hand, you can use the tack hammer to tap it back down to make it flush, then use the screw driver to get is just below the surface of the band.
This was on a Seiko Dive watch SKX007. This has the metal links joined with pins, which, you will find, are split/spring down their length.
I used a neoprene mouse mat as a work surface, which was ideal as it
allows the pin to move out, whilst supporting the links and stopping
any slippage. I also rigged a table lamp close by.
There is an arrow which shows in which direction the pin needs to be pushed to remove it. Look carefully and you see that one end of the pin is slotted a little, the other is plain. Push the plain end in the direction of the arrow firmly... it's a leap of faith.
As a tool, I used a cocktail stick to start with. It required firm pressure and then it suddenly gives. I was able to draw the pin out by hand, but used pin nose pliars in one instance, as some pins offer more resistance than others. In most cases the cocktail stick worked (I got through a few). I then graduated to a thumb tack which was more reliable, but metal to metal, so a bit more worrying.
Sliding the pin back was simple, though take care to get the smaller links the right way up when it is re-threaded. I pushed it home the last few millimeters with the flat side of the pliers, giving a final push with the cocktail stick. Good luck. Simplysimon.
solutions already mentioned(casio wristband) worked for me. However the first link took me forever to remove as I found it hard to envisage what I what attempting. Attached is a pic of a disassembled link which hopefully might help someone....BPB
I have a similar watch and removing the links are not easy. There are pins in certain links that have arrows on the inside of the band. I used a push pin to remove the pins in the direction of the arrows. Snip the end of the push pin with a wire cutter or pliers so that it fits into the hole and tap the top of the push pin with a small hammer until the other end of the pin is exposed enough to extract it with a set of needle nosed pliers. Repeat for other side of link. When the pin is extracted, twist the link inward and it should snap out.
Remove the link and reverse the procedure, placing the pin in the opposite direction as it was extracted. You may have to tap it gently with the push pin and hammer to get it to go into the holes flush.
It takes a little while and some patience, but if you can get someone to hold the band for you while you tap the pin, it will be easier. Also, if you remove the spring loaded pin from the band fastener so the band can be laid out straight, it will also be easier. Good luck!
