My logitech quickcam 9.0.2 is not compatible with windows 7
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Logitech Camera Drivers for Windows XP Vista Windows 7
SOURCE: QuickCam v11.8 and windows7
It doesn't let me even install it from the disc. It says that logitech isn't compatible with windows 7 every time I try. >:L
SOURCE: is not compatible with windows 7
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility". This will
allow you to choose on what type operating system your program will run.
Just reply back if it still doesn't work.:D rate and vote for me:))
SOURCE: Driver for logitech Quickcam Express V-UH9 for windows 7
I'm afraid there is no solution. Logitech took the decision not to support older webcams like this in Windows 7. If you look at the driver matrix on the following site, you'll see there is no Windows 7 driver... http://logitech-en-amr.custhelp.com/app/answers/detail/a_id/3428
