Greetings,
If you click the link below it will take you to a video demonstration that explains step by step what you need to do to convert your Kirby into a carpet shampooer. The vacuum in the video is the Kirby Sentria, but the procedure is the EXACT same as it is on your Kirby Diamond Edition, Kirby Generation 3, G4, G5, G6, etc. All Generation models have the same process of converting the vacuum into a carpet shampooer.
Instructional Video On How To Attach The Kirby Generation Series Carpet Shampoo Attachment:
http://kirbywhq.powweb.com/videos/Carpet_Shampoo.mov
I hope that this video was helpful to you. Please feel free to request a clarification if you have any further questions about the installation, I'm always more then happy to answer any question, seriously.
If you did find this video helpful, please kindly rate my soltuion as Helpful by clicking the Thumbs Up Icon at the the bottom right hand corner of this page.
Thanks for watching!
Chris
SOURCE: kirby diamond edition - shampooer
1. Raise the vacuum head all of the way up. 2. Remove the vacuum head by removing the belt and releasing it. 3. Place the shampooer head on the vacuum by securing the clamp and them put the belt on 4. Take the bag off of the vacuum by twisting at the base just slightly outward and lifting upwards and unclamp it from the handle 5. Put water and cleaner into the water resevoir. 6. Put the reservoir on to the kirby where the bag was by holding it parallel to the vacuum then using both hands, twist it outward slowly until it goes down onto the unit then twist back to parallel position. 7. Put the coil looking piece on the shampooer head on top where the hole is...it will only fit one way successfully. 8. Put the other end on the under side of the water reservoir. 9. Lower the shampooer head all of the way down on the carpet just like you would the vacuum head 10. Turn on the vacuum and reach down and turn the knob at the top of the reservoir, this will begin putting cleaner (tons of foam) onto the carpet. Just work in 3' x 3' sections, turning off the foam intermitently until you are finished. I hope this helps.
