Your Gateway either has corrupt drivers or has forgotten your WiFi.
Go into your device manager and remove the WiFi device. Then have your computer search for any hardware changes. It will find your wifi device and reload drivers. If this does not work, you have a bad wifi card.
Hi Fred! I have checked the specification of your laptop here and found that your laptop is Wi-Fi capable and wi-fi drivers are available and can be downloaded and installed here. (if required) Most Gateway notebooks have a designated multi-function button or function key to turn your wireless on and off. There should be a tiny slide switch or button with a small antenna
symbol. There should also be a light with the same symbol to show when
it is on and from the keyboard Press Fn+F2 to enable wireless.
Let me know if any further clarification/ assistance is required.
Good Luck! Dont forget to appreciate the solution if I could have been of any help! CreativeTECH
if i was you i would load up a version of win xp on another hard drive inserted into your laptop, load the drivers for the laptop including wi fi drivers then see if ok. if not you can be sure its a faulty wi fi card in your laptop,you need to disable internal wi fi card remove,replace it.but first try borrow a pcmcia wi fi card just to check if everythings ok
