Pride Jazzy Select 6 Indoor Power Wheelchair Logo
Posted on Mar 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Somehow I have locked my Jazzy 6 Select Electric wheelchair. I know you need to push the trottle but I really don't know what to do.
Anonymous
Level 2:
Scholar:
  • Expert 61 Answers
  • Posted on Mar 29, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
61
Questions
0
Helped
47588
Points
105
Try This:
To unlock the power chair.
1. Use the on / off button to switch the control system on. The maximum speed / profile indicator will be rippling up and down.
2. Deflect the joystick forward until the control system beeps.
3. Deflect the joystick in reverse until the control system beeps.
4. Release the joystick, there will be a long beep.
5. The power chair should now be unlocked.
Hope it works.
How to stop squeaky wheels
My tires squeak how can i fix the problem and what ... - Fixya
www.fixya.com > ... > Pride > Jazzy Select 6 Indoor Power Wheelchair
Apr 14, 2012 - my tires squeak how can i fix the problem and what can i use - PrideJazzy ... Question about Pride Jazzy Select 6 Indoor Power Wheelchair ... I have a mpv 5 hoveround wheel chair and I now have a flat on the front left tire.
[PDF]Jazzy Select Series Owners Manual - Pride Mobility Products
www.pridemobility.com/...jazzy/us_select_series_om.pdf
Pride MobilityJazzy Select 6 with Power Seat. JAZZY. SELECT SERIES. Including Models: Jazzy Select, Jazzy Select 6, and .... Battery charger for indoor use only. .... Take wide swings with your power chair's front wheels around any tight corners. ... desired, allow it to come to a complete stop by releasing the joystick, then push the ...
[PDF]Jazzy Select Series - Pride Mobility Products
2answers
What the lights moving right to left on jazzy select 6 power chair
If you are moving as soon as you turn on the chair, the lights will move from right to left. Try waiting a few seconds and see if the lights stop moving. If they do stop, then you can move forward. Hope this helps.
Where is the freewheel lever located on the jazzy 1113?
Original Jazzy Select has push-down levers on each side behind powered wheels. These manually disengage the brakes on each motor individually. They are about 6 inches long and push down an inch or so. I don;t know about other more current models, The 2 smaller wires to each motor disengage the brake when given power (24 volt, I think). The 2 larger wires run the motor.
HOW DO I GET THIS JAZZY 1120/2000 TO MOVE FORWARD? AT THE PRESENT TIME IT APPEARS TO BE IN A LOCK POSITION. WHEN I PUSH THE JOYSTICK FORWARD IT WILL GO FORWARD AND STOP THE SAME FOR THE REVERSE IN A LOCKED...
Good evening.Download this Adobe Acrobat Document:- troubleshooting_2007 SHOPRIDER.pdf
In there you will be delighted what you find,its 36 pages long.Pages 1 to 5 batteries and chargers 6 to 18 on scooters & 19 to 36 on wheelchairs.Any problems ask again.Have a nice day.Colin.
Replaced battery in jazzy 600 wheelchair and the light comes on, but wheelchair will not do anything.
Make sure that your drive wheels are engaged and the power chair is not in the freehweel position (so it can be pushed).
I need an owner's manual. Don
Contact your dealer or manufacturer. The usually run $20 plus shipping.
2helpful
Power good, but no motor functionality - Jazzy Select
hand control is locked. turn chair on push joy stick forward til it beeps then pull it back until it beeps then put it in neutral ( joy stick in the center) then it should be unlocked
What kind of Jazzy select 6 power chair does my Mom have? Serial number J92037090688C30. We live far away from each other and I need to know what she got.
Here's a link to Pride Mobility, maker of the Jazzy wheelchairs. This takes you to the Select 6; there's also a Select 6 Ultra. Just click on models and it will display all of their line of equipment.
4helpful
Wiring Diagram Pride Jazzy 1120
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are two levers just under the seat at the front. Pull the forward and to right to lock position, which will release the gear so that the wheelchair can be move about without any electric power. Bear in mind though that releases the gear, still too heavy to push as normal wheelchair. Give a go, to find out for yourself.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
