SOURCE: samsung yp-k3
1. You can download the software from the samsung website
2. The usb message is nothing - it is just telling you that you have a USB 1.1 hub but you well get better transfer speeds using a USB 2 hub, or you can connect it to a usb port directly
SOURCE: Cannot chage YP-K3 player
The usb message has nothing to do with the ability of the unit to charge. It just means that the port on your computer is recognised as a USB 1.1 port.
It is more likely that the battery no longer holds a charge. The battery can be replaced but it is difficult to open up the unit without damaging the casing. There are instructions on opening up the unit on youtube. Other than buying a faulty unit with a working battery I don't know how to get hold of the batteries. Be careful when replacing the battery. If it is connected the wrong way you will fry your unit.
SOURCE: MTP Error
When the YP-K3 2 gb device is plugged into the USB Port, the system says "Found New Hardware, Samsung YP-K3" which then switches to "MTP Device" and then fails on an MTP error. It seems to be searching for a driver, and cannot find one. H E L P!!!!!
SOURCE: I lost the installation cd for my YP-K3 mp3 player... what to do?!!
Pls. help me to install my yp-k3 player
SOURCE: can i ask sometin'? my samsung yp-k3 does not recognize by d comp
Well, in my knowledge the USB cable might of gotten yanked out of the port and one of the 4 cords might of slipped on to the wrong power/transfer contact. If so it might of put out the wrong voltage to the battery and "fried" it so you might need to buy a new battery and cable to make the divice work again. Sorry for any inconvenience
