Kenmore washer - water won't drain. It stops between the rinse and spin cycle. What do you recommend?
If the water drains between the wash and rinse cycles, your motor and pump are probably OK. If this is a machine with a dial, try a different cycle, like normal instead of heavy duty. If that works and the machine completes the entire cycle then the timer probably has a bad spot. You might try to find a replacement timer if that is the case although I didn't have any luck with my 10 year old washing machine. Best of luck
