Jenn-Air JGR8850 Gas Kitchen Range Logo
Posted on Mar 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a jenn-air gas range with a f9 code come on with oven is use. What is this code.
Anonymous
Level 2:
  • Expert 230 Answers
  • Posted on Mar 22, 2010
Anonymous
Expert
Level 2:
Answers
230
Questions
8
Helped
81015
Points
693
Hi There
I have found this code for you and hope this helps you.Let me know how it goes.
F9 Door lock safety circuit on power relay board sensed Replace power relay boardThank you for writing to fix ya.
Best Regards Richard
F9 code flashing on Bosch induction cook top
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Jenn Air Kitchen Range Model jer8650 oven stopped working and code f9 appeared
Try shutting it down at breaker then back on. This helped me.
2helpful
Jenn-Air JGR8855 oven light stays on
F9 is for the door lock relay fault. Does the lock work OK? Is anything else acting funny on the unit?
I get an F9 in the window on the oven what does this mean
Below are the details of error code F9...
JENN AIR
Fault : F9
JENN AIR
Fault:F9
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
1helpful
Oven was off...woke up to oven beeping and the F9 code came up & door is now locked. What is F9??
This waht F9 mean
F9 Door latch Check door latch components.
You will need to replace door latch
1helpful
Model JGR8855ADS is reading Code F9. what does
Hi There
I have this code for you. hope this helps you.
F9 Door latch Check door latch components.Thank you for writing to fix ya.
7helpful
3answers
I get failure code F9-3
What a scam by service personnel.
-Simply press "Stop/Clear", then gently push the door handle until "Lock" appears on the screen. Press "Stop/Clear" again and the door unlocks itself!
J. Kalicak
10helpful
2answers
I am getting a F9 on front of my oven
We solved this by holding in the door/light switch, hitting "clean", then pressing stop/clear for about 3 seconds.
1helpful
2answers
Jennair 8855 F9 error
take a 24 inch peice of coat hanger make a small u in one end and insert it from the left side gentlw fish for the door latch hook and pull it over to un latch the door and let me know if the code goes away
Top Jenn-Air Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
