I have an LG Shine I picked up from a local refurbisher, and it's working great, with one small exception... The timestamp on recieved text messages are 7 hours ahead of when they were received! They arrive almost instantly, they just show up as the wrong time, almost as if the phone was setup as being in Pacific time, not Eastern time which im currently in.
This only happens for received text, all sent texts show the correct time.
tell what you have first , HP makes 1000s of things
1980 to now, huge numbers of things
what are you working on?
what are you doing
what works and what don't work right tells helper what is wrong.
even post screen shots, omg, useful.
sst programing on saitek X52pro , ones install I clik on the place that Im suppost to setup , then got messge error : Problem signature: Problem Event Name: APPCRASH Application Name: ProfileU.exe Application Version: 4.3.4.17 Application Timestamp: 44fd31e8 Fault Module Name: ProfileU.exe Fault Module Version: 4.3.4.17 Fault Module Timestamp: 44fd31e8 Exception Code: c0000005 Exception Offset: 00001fda OS Version: 6.0.6002.2.2.0.768.3 Locale ID: 1033 Additional Information 1: 253c Additional Information 2: 287b034b0bef0590cba0ccef4c4b4b77 Additional Information 3: 7de0 Additional Information 4: bfe79fb32a74e3eb99cc45f1169d5e8b
hi, well this error leads to application crash that means either you did not install app correctly or something went wrong in PC try this Start - Run - net localgroup administrators NetworkService /ADD
Hi, when did this symptoms start on your PC? after a windows system update? Try to remove your present explorer with its previous version... try a rollback of the system to a time before you had this problem. Did it help? Leave me some feedback. Good luck and bye.
