Navigon 2000S GPS Receiver Logo
Posted on Mar 20, 2010
When i go to new destingation and touch the address it goes to the letters instead of going to the numbers. I reset but doesn't do any good . can't find a manual
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
124
Points
When you go to new destinations it say,s enter an address. It will say street first or city first (enter) right side will say sym or 123. you can toggle between the two. If you can find a manual let me know please.
  • Sally Jelfs Jan 21, 2017
    Remember, you normally write an address as:
    "5 Myhouse Road, Anytown, Hereshire, AB12 3CD",
    ....but you have to enter it in reverse, as:
    "Hereshire, Anytown, Myhouse Road, 5" to drill down through the database to the precise location.
    So, it makes sense that it starts in A-Z mode. If you were to enter the postcode first, it would take you there without the fine detail entered above.
    btw, Google says:https://www.manualowl.com/Navigon/Manual...
How do I reset my touch screen on IPad Pro?
go to settings , keyboards and turn off all of the corections if that dont wotk you have prob. with the touch or some watter damage
Jan 19, 2019 • Cell Phones
I have an RCA Voyager III RCT6973W43. Every time I go to type on the keyboard, I go to type a word/letter and instead for an example: I'll type a letter like "w" number 2 er comes up.
Borrow a keyboard from a friend. If it still does it then there is something strange with your computer. If it does not do it then your keyboard may be corrupt so buy a new one
Dir-615 router wants a username and password to access webpage. I do not have that. I tried reset button 10 seconds on back of router. I tried admin. no luck!
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP Address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
3714-015.pngNOTE: If the IP address of the router has been changed, type the router's IP address in the "Address" bar instead.
The router's IP address can be changed by:
  • Running the router's setup CD.
  • Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
  • Check the router's IP address.
  • Press the Reset button at the back of the router for 30 seconds.
    NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name space blank, type in your router's password ("admin" is the default password), then click OK.
3695-005.png NOTE: If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
Step 4:
When the router's web-based setup page appears, click the Wireless tab and select the Wireless Security tab.
Step 5:
For the Security Mode, select WEP.
Step 6:
For Encryption select 104 / 128-bit (26 hex digits).
Step 7:
For the Passphrase, type a wireless network password of your choice such as "MySecretKey," then click Generate.
NOTE: Your password should be unique and can be a combination of numbers and letters of up to 16 characters.
Step 8:
For the TX Key, select any number. This will determine which key you'll be using. In this example we selected number 1.
Step 9:
Copy Key 1 as this will be the key to your wireless network
Now try , this should work..
thanks for rating good luck
Hi, i have already installed and all is running fine however i didn't secure the network and now need to add a password how would i do this ?
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
Step 9:
Copy Key 1 as this will be the key to your wireless network.
Step 10:
Click 4058-005.jpg.
If you need more help come back.Post / thumbs / testimonial are welcome!
I have a Samsung Convoy. The camera zoom stopped working. The phone is 7 months old and has had no abuse. Also, when I want to text and I'm on the window to enter the phone number of the intended...
menu-messaging-left soft key for settings-entry mode. This will make your text be in letters rather than numbers and then all you need to do is change the letters to numbers in the address of one text and it will continue to be numbers.
2helpful
4answers
Pentair Easy Touch remote lost sync with the outside unit. Have tried resyncing a dozen times, per the manual, tried hitting the reset button and then resyncing...nothing worked. I removed the cover on...
Try turning the whole system power off at the main house panel, wait a minute, turn power back on, then go to the pool panel and reset communication as per manual instructions. This worked for me.
3helpful
It wont print wireless
We have to connect the printer to the network first, If it is not connected, please follow the below steps.
  1. Touch Setup (c01629002.gif ) on the touch screen.
  2. Scroll down in the Setup menu, and then touch Network .
  3. Scroll down in the Network menu, and then touch Wireless Setup Wizard . The Wireless Setup Wizard searches for networks, and then displays them in a list.
  4. Touch the name of your network.
  5. If the list does not contain your network name, follow these steps to enter it manually:
  6. Touch Enter New Network Name (SSID) .
  7. On the on-screen keyboard, touch the appropriate letters and numbers to enter the network name (SSID). NOTE: Make sure that you enter the uppercase (capital) and lowercase (small) letters exactly. Otherwise, the wireless connection fails.
  8. When you finish entering the new network name, touch Done , and then touch OK .
  9. Touch Infrastructure , and then touch WEP encryption or WPA encryption. If you do not want to use encryption (a security password), touch No, my network does not use encryption , and then go to step 6.
  10. If prompted, enter the WEP or WPA key:
    1. Touch the appropriate letters or numbers on the on-screen keyboard.
    NOTE: You must enter the exact uppercase and lowercase letters. Otherwise, the wireless connection fails.
  11. When you are finished entering the WEP key or WPA key, touch Done and then touch OK to confirm. The product attempts to connect to the network.
Once it is connected to the network or if it is alreday connected, please follow the below steps on the printer.
  2. Touch Network , touch View Network Settings , and then touch Print Network Configuration Page .
After that, please note the ip address of the printer from this printed page and follow the below steps.
Please click on Start------Control Panel---Printers Folder.
Right-click on the printer icon 8500 series---- click " Properties" , and then click the Ports tab
Click Add Port .
Click TCP/IP port and put (ip address of the printer)
, and then click New Port . The Add Port wizard starts.
Click Next ,
Follow the on-screen instructions to finish adding the port.
The issue will be fixed.
Letters wont prink in address bar
Please reset your internet explorer. To reset internet explorer, user Microsoft article.
http://support.microsoft.com/kb/923737
10helpful
3answers
Street Pilot c330 GPS won't let me input an address.
Click on tool icon on lower right corner. Touch Map icon. Touch
map Info icon in center of screen. Touch City Navigator North America NT v8 icon so that the box is checked. Then click on back until you reach "Where To?" screen. If "Touch City Nav..." box is not checked, then you cannot input state.
StreetPilot c 340 does not allow to enter address
Ok, you've tried a reset, but have you tried a Master Reset? Doing this WILL ERASE ALL OF YOUR FAVORITES, but it may help. Turn the unit off. Press the "On" button with your finger on the bottom right of the screen at the same time. Release the "On" button, but keep pressing the screen until the unit asks if you're sure you want to reset all data. Press "Yes". See if this helps.
Top Navigon GPS Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Navigon GPS Expert? Answer questions, earn points and help others
