I am using my 32'' lcd as monitor and I need to find the driver to install on my computer. The resolution is not looking good right now. Please help.
You need to change your resolution on the computer look in the desktop right click select properties , select settings, play with the resolutions until you find one that is ok, select advanced, then select displays adjust the refresh rate to some place between 60 and 75 hz, if it doesn't work wait it will return to the previous setting if it works select ok and you have the video setting as good as they will get. hope this helps
