I cant get my background to load, and I cant find any options for active desktop, web content, or a Web tab under Customize Desktop in Display Properties/Desktop or anything
Hi friend,
For active desktop please follow the given steps and surely you find the solution,
Firstly click on the start button and go to RUN option.
Type regedit and press ok, Registry window will be open. Than follow the steps-
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Desktop\Safe Mode\Components
Change the value of DeskHtmlVersion to zero instead of decimal 272.
After that press F5 button of keyboard few times or restart the system
Good luck,
Thanks
In some cases, say when you're building and testing a webpage locally (Local Machine Zone), you may still see the Information Bar when the web page executes any script, initiates a Pop-up windows, or a download. For testing purposes, one needs to follow any of these workarounds:
Rename the .HTM file to .HTA (Example.. Index.HTM to Index.HTA and test the file locally). HTA files have more privileges than the HTM files, can run active content on Local Machine by default.
-or-
add the Mark Of The Web code such as <!-- saved from url=(0023)http://www.contoso.com/ --> to a Web page, where the (0023) value is the string length of your URL that follows it and Contoso is the name of your Web site.
To accomplish this via the Registry, modify the following registry value:
HKCU \ Software \ Microsoft \ Internet Explorer \ Main \ FeatureControl \ FEATURE_LOCALMACHINE_LOCKDOWN
In the right-pane, create a new REG_DWORD named iexplore.exe and set it to 0
Values:
0 - Allows a Web page to run active content in your computer
1 - Disallows a Web page from running active content in your computer
To allow any CD to run scripts and ActiveX controls on your computer:
In Internet Explorer, on the Tools menu, click Internet Options. On the Advanced tab, scroll down to the Security section of the list. Select the Allow active content from CDs to run on My Computer check box, and then click OK.
