Nokia 6300 Cellular Phone Logo
Posted on Mar 20, 2010
My cell is china phone, and i cant receive mms msge. what seems to be the problem? how can i activate my mms settings?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
72
Points
After many reserch china mobiles tottaly kabada...mms ke liye koi aacha cell phone use karo otherwise contact to service provider
Sir i have sghf480i set im unable to send photo msge to my ferinds ?
You should check MMS profile setting. The proper setting should be configured before sending or receiving MMS. To retrieve the MMS automatically, you should set the settings at "Auto download" settings. To check,
    1. Go to Message from the idle screen.
    2. Go to "Settings" and then "Multimedia messages."
    3. Select "Receiving options" and "Home network."
    4. Go to "Foreign network" menu and check the status
    5. If it is set at "Auto download", you can receive MMS automatically.
    6. If it is set at "Manual", you should operate MMS retrieve function manually.
For more details, check out this link http://skp.samsungcsportal.com/PRIVOXY-FORCE/integrated/popup/HtgDetailGuide.jsp?cdsite=sg&seq=5310
Mar 10, 2011 • Cell Phones
1helpful
Its a nokia phone made in china and i recieve a mms message then i cant view through my phone besides my gprs is activated,what would i do in order to open my mms message recieve?
Try retrieve the message for several times. check MMS settings. or may be the MMS has expired at the server and not available to download.
Mar 02, 2011 • Cell Phones
How to activate gprs and mms of my china black berry mini8000c?
GPRS and the MMS settings are send by the network operator.. so call them and ask them to send you the settings for the same. After receiving the settings, install them and restart the cell.. and enjoy :)
hope this has helped you.. Thanks..
Sep 23, 2010 • Cell Phones
I want to activate or open my mms and gprs..but its china phone..
Thank You
To get GPRS/MMS setting, you need to contact your service provider through phone or go directly to their office.
They will send you the settings for your model. You will receive service settings in the special text message called as smart message. Please save the settings to your phone and set it has default settings. Then you can start using the GPRS/MMS in your phone.
Thank You
Do i need to activate MMS on my phone , cant recieve pics from my sons phone/T mobile is the provider my phone is MY7***sagem,phone receives the photo,but cannot display it,it says "rejected".
Yes you need to activate it in order to receive mms, just contact the customer service of T-Mobile and ask for the mms settings for your phone.
Cant download mms picture n95 china
You will need to configure MMS manually For china mobiles manuals, software and drivers check chinamanuals.com (search for your model or just ask them) - they have a N95 manual with provider settings!
15helpful
9answers
How can i activate GPRS and MMS setting for my china mobile phone
hi there,
here i post some procedures you can follow for activation your GPRS and MMS.
Automatic Activation of GPRS/MMS/WAP
Go to Menu -> Services -> WAP -> Settings -> Edit Profile
Select Sun WAP, Press Activate Profile and Save
Go to Menu -> Messages -> MMS -> Message Settings -> Server Profile
Select Sun MMS, Select Activate Profile and Save
For corporate accounts, fax a letter of request and ID of the authorized signatory to 395-0138. Approval and activation maybe slightly delayed.
Text “ACTIVATE” and send to 2300
If unable to activate,please call Sun Customer Hotline (200 on your mobile phone).
* If surfing or MMS sending does not work or results in an error, please proceed to the next step for manual setting.
Manual Activation of GPRS/MMS/WAP
Setup/Enable GPRS
Go to Menu -> Services -> Data Account -> GPRS
Select Sun GPRS
Account Name: “Sun GPRS”
APN: “wap”
Select SUN MMS
Account Name: “Sun MMS”
APN: “mms”
Exit and save settings
Setup/Enable MMS
Go to Menu -> Messages -> MMS -> Message Setting -> Server Profile
Select Sun MMS, Select Edit Profile
Rename Profile: “Sun MMS”
Homepage: “’http://www.mmscenter.suncellular.com.ph”
Data Account: “Sun MMS”
Connection Type: “HTTP”
Proxy Address: “202.138.159.078”
Proxy Port: “8080”
Select Activate Profile, Yes to activate profile
Setup/Enable WAP
Go to Menu -> Services -> Wap -> Settings -> Edit Profile
Select “Sun WAP”, Select “Edit Profile”
Rename Profile: “Sun WAP”
Homepage: “http://www.suncellular.com.ph”
Data Account: “Sun GPRS”
Connection Type: Select “HTTP”
Proxy Port: “8080”
hope it will help you to solved your problem or still you have any question regarding on it that you can't understand you can go on this site and log on.
http://www.kokeytechnology.com/gadgets/cell-phonesmobile-phones/how-to-activate-gprs-and-mms-of-nokia-phones-powered-by-sun-cellular/
1helpful
2answers
N95 China mobile Phone
ur wrong in my n95 china mms and gprs are working properly i know its not the original one but its quite ok for me. you can even connect it to your dvd player with usb and play all the multimedia you can put on its external flash memory you can upgrade up to 8gb mem.
1helpful
I cant send nor receive pictures
Hi Kim, Contact your provider and ask them to send you there WAP and MMS settings, usually when you recieve theese you switch off your phone, power it back up and YOU need to send a picture to activate the MMS settings with your provider. Good Luck!
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
