You must have broken the cable somewhere. If you move it around you might get it to come on, try it all over to determine where the break is. If very close to the headshell you might want to consider a new cable. If in the middle you can cutt it off before the break and fit a new plug. Then get an extension cable to complete the length.
If at the plug end follow what follows:
Cutt the old ******** and buy a new plug. Cutt it off 10cm before the plug end if the break is the plug section. Most hadphones are fitted with a 3.5mm jack. You will need to solder the wires on. You will find when you have baired back the cable two coloured wires and two earths. The earths fit together on the metal flange that comes out of the main body of the plug. The coloured wires go on the the two smaller flanges (left and right channels). If you get them wrong way round reverse them you won't do any damage. Make certain the earths don't come into contact with the R & L channels wires or terminals and the left or right don't touch each other. The T shaped end on the large flange is to grip the cable body, bend the tabs to grip the cable.
