Something is still plugged with lint,if the vent line is long blow it out with a leaf blower to clean it out,you have to clean out the duct that the lint filter slides into,if the filter is on top remove the vent line,remove the back panel,remove the lint filter and the two screws in front of it and remove the four screws and clean out the duct,if the filter is in front take off the bottom panel,remove the filter and clean the duct,also vac out the inside of dryer where the motor is,when the dryer gets to hot the thermal fuse pops as a safety so you still have a block somewhere
could have abad thermostat,does the dryer cycle,does the heater turn on and then off,if the vent line isn't blocked and you can try to run dryer with vent line removed from the back of dryer to check you could have a bad thermostat or the heater is bad,one of the coils could be touching the metal bracket but something is overheating the dryer most of the time it's from bad air movement
ON your Dryer that keeps blowing Thermal Fuses . First I don't want to over ride someone
Thats helping you. I Hope not First thing I'd like you to do is , Set your dryer to AIR Fluff
That should be no heat Then let it run for about 2 Minute or so now is your dryer putting
OUT HEAT If so get back to me
U need to replace the main control,bad heater relay!
