To save caller ID with a name in Panasonic KX-AT7730, you need to follow these steps:
Press the "Program" button on the phone.
Dial "9" to enter the "Caller ID" setting.
Dial "1" to enter the "Caller ID Memory" setting.
Dial the memory location number (0-99) where you want to save the caller ID and name.
Enter the caller's phone number using the keypad.
Press the "#" button to move to the next field.
Enter the caller's name using the keypad (use the alphanumeric keys to enter letters).
Press the "#" button again to save the entry.
Repeat steps 4-8 for each caller ID you want to save.
Note: Caller ID service must be enabled on your phone line for this feature to work. Also, make sure you have enough memory locations available in your phone's memory to save new caller IDs.
Panasonic KX-TA624/824 automatic Caller ID logging
How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824) System Programming:
In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
The Caller ID Indication button will light up only when the system has logged UN-answered calls.
Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
You can erase the entire Caller ID log by pressing Intercom, then 70**#
You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
The Star Talk Flash is a voice mail prduct. The caller ID feature is a phone system feature. If your system is a norstar CICS or a MICS the caller ID will work only if you have the caller ID capable central office circuit packs installed. Look on the card and see if the label has "CLID". If it dose there is also additional programming required for each set under.... terminals &sets/telco features/featue assignments/show line/caller ID...set:Y. You also have to program (under sets) /telco features/caller ID: Y.
Yes, u need to program all the caller information into the phone. Please refer to the manual page 5-6 for how to storing caller's information names and numbers.
There are a few other things you need before it will just work on your phones. You need to get Caller-Id activated by your carrier on each of the 4 lines. You also need to make sure your system has a Trunk card capable of Caller-Id. The card in your systems should be labeled CID.
After this you still need to program the lines for Caller-Id in the configuration section of programming.
You have to have a few programs already set. In admin programming, you will need to set #316, #317 and #318. Then you need to program a log button on the phone, which is Feature 23.
When you hit the log button, you then will see the options to scroll through the calls.
Unfortunately just adding caller ID to your phone line will not work with many business phone systems, especially older systems.
You can have this phone on one of several different Toshiba phone systems. The system must have caller ID equipment installed and programmed correctly for caller ID information to be shown on your phone's display.
Caller ID information is transmitted between the first and second ring. With business phone systems the system itself needs to collect this information and then pass it along to any phones that are programmed to ring at any given time.
This is a Definity system phone. The phones themselves have nothing to do with caller ID, it's the system that handles it. The phone line has to have the caller ID service AND the phone system needs to collect the information and then display it on your phone. If you are sure caller ID service is available on the phone line you are using than this is a programming issue. Definity is a huge system and you cannot program it yourself. Someone in your building is either in charge of making simple changes in the phone system or contacting the company that makes these changes for you.
