I have a Proform CT-1160 that the incline does not go up or down. Is it the motor or a fuse that needs to be replaced?
ProForm Treadmills have a reset procedure for the incline function. With the key inserted in the console, activate the incline; while the incline is changing, remove the key. Wait 30 seconds, then replace the key. The incline should to maximum, then to minimum, resetting its limits. It worked for mine just 10 minutes ago; the procedure is in the manual if you have it. Good luck!
Testimonial: "Great thanks"
Honestly, without looking at the unit, there are too many things it could be. Yes, it could be the motor or the fuse but it could also be a bad board. Without testing the different components, I cannot give you an answer.
Testimonial: "Ok. Thanks"
