The Cobra 29, like most CB radios, contains a reverse-polarity diode whose purpose it is to protect the radio against accidental reverse-polarity hookups. Normally all you will need to do is replace the fuse, then hook the radio up correctly.
If that doesn't get you going, then possibly the polarity-protection diode is now shorted and will have to be replaced (or removed - not recommended).
Beyond that, my experience is that the next component most like to get damaged is the Audio Output circuit, either an IC or a power transistor (larger than a regular transistor). At this point you're going to have to take it to a repair shop.
if this is a used radio its because some golden screwdriver got into it but if its a new one then its the radio.Check the reverse polarity diode in either case to see if its burnt. If so replace it and see if it happens again.
The radio was probably wired backwards at some point. There is a reverse polarity diode inside that must be replaced to fix this. If you have continued replacing fuses and plugging it back in, there may be further damage such as finals or audio amplifier chip as well. you will need to take the radio to a qualified repairman for service. If it is simply the reverse polarity diode, your bill should not be more than an hour's labor charge.
For 25 cents, they could have installed a diode to prevent this problem, but now there isn't anything you can do, as the damage has been done by the reverse polarity.
