Re: Kohler Fairfax single control kitchen sink faucet
Remove the air-irater at the end of the faucet where the water comes out. That is where 99% of clog are on faucets. If that does not do it then you need to replace the cartridge.
Good Luck and please rate 4 thumbs up for the free answer.
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed. He has a very extensive list of repair parts for faucets.
Remove the spout and replace the o-rings and don't forget to lube the o-ring before assembling the faucet.
You should use a lube designed for the applicationcommonly know as plumber lube.
Kohler K-79402-CP aerator kit
Kohler K-78250
Kohler 1001100
You might try to replace aerator on end of spout if water is leaking around it, or you might try to replace cartridge. VALVE (CORALAIS AND FAIRFAX)
K-GP77548
$14.80 List Price
First thing to check is if it has a strainer on the spout that has debris. The second thing is if you have a sprayer attachment the diverter valve is a chronic problem with kitchen faucets.
was the base installed under the faucet..is there a single hole in granite...faucets usually come with a long base to cover the holes in sink..or with one round ring for granite installation..which the faucet should be mounted on..
You will need to buy the o-rings to fix it. You can buy at most hardware stores if you know how to turn off the water you can fix this with more instructions. Let me know if you need more help.
