If those codes dont work try the last three(or four) numbers of your TV's serial number.
On my universal remote is just a matter of holding down the TV button till the light stays on, then punching in the three digit TV code. When the TV turns off it's the right code. But read your manual for your controller.
These are generic code search instructions for Phillips/Magnavox Programing with Code Search
1. Manually turn on (TV,VCR,etc.) to be controlled. 2. Press and hold Code Search button until red indicator stays on. Release the Code Search button. 3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blinks, then stays lit. 4. Press the Channel Up button repeatedly ( up to 300 times ) until the device to be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code. If the device you are installing does not have a Channel Up button use Play(VCR only) or Power, on all other devices.
have you programmed the remote? or you can go into the menu button on the front of the tv, use the up down (either the volume or channel may move the selection) to locate the caption on/off control and turn it off that way. if you need the manual try here
I found the code by starting the full library search and was lucky to find it again...for my Magnavox the code is 919...this makes both the upper and lower Volume and Channel buttons work for the television, which just makes it more convenient to use. Thanks
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf This
is the user's manual for a Phillips remote control. There is a list of
codes in it. They should be rather universal. There's also instructions
as to how to program it. I believe that there is a way to program it
without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
Press the Channel Up button repeatedly (up to 300 times) until the
device could be controlled changes channel. The red indicator blinks,
4.
4.
